Activity › Forums › Adobe After Effects Expressions › Sine Wave get closer depending on the maximum and minimum value
Posted by Pablo Bonilla on July 8, 2024 at 4:17 pmHi everybody :),
I want to create this effect, picture attached.
-I understand the Amplitude of the Sine waves would increase less in the center and more outside
-Anybody knows how can I connect the position in X axis from the WAVES with the value of the max/min, so they get closer or away depending on the value?
Thank you very much
Pablo Bonilla replied 2 years, 2 months ago 2 Members · 2 Replies -
Hector Vera
July 9, 2024 at 8:55 pmI found something related to this that may be able to help you in this situation. And you are correct that the amptitude of the sine waves at the center would certainly be lowered than compared to the amptitude at the Edges. Follow these steps to see if it can help you with this project:
Here are the steps:
- Create a new composition with a black background and add a new solid layer.
- Apply the Turbulent Noise Effect to the solid layer and adjust the settings as desired.
- Use the Wiggle Expression to add movement to the turbulence. Here is an example expression:
wiggle(5, 30)
This expression adds jitter to the movement of the turbulence. You can adjust the values to change the amount and speed of the jitter.
- Apply the Echo Effect to the layer and adjust the settings as desired. This will add a glow effect to the turbulence.
- Apply the Transform Effect to the layer. You can use this effect to adjust the position of the turbulence in X axis.
- Add a Slider Control to the Composition panel.
- Select the Transform effect on the layer and click on the stopwatch icon to add the expression. Use the following expression:
value + (3 * (pickwhipping_range))
This expression will add the value of the slider control to the original position of the turbulence. The value “3” is a random value used as a multiplier. You can adjust it to control the speed of the movement.
- Add a new Null object to the composition and name it “pickwhipping_range”.
- Select the Null object and click on the pick whip tool (it looks like a double-ended arrow).
- Hold down the Alt key (or Option key on a Mac), click on the position property of the transform effect on the layer, and drag it to the pick whip button on the Null object.
- The position property of the transform effect on the layer is now pick-whipped to the pick whipping range on the Null object.
- You can now animate the position property of the Null object along the X axis to control the position of the turbulence.
Hopefully these will help you, if any questions, you can let me know just incase!
Pablo Bonilla
July 10, 2024 at 12:04 pmHi Hector, thank you so much for the response. Really appreciate, I will try to build as you said and contact you back, thank you.
