Activity Forums Adobe After Effects Expressions sine wave driving RGBA value trouble
  • sine wave driving RGBA value trouble
    Posted by John Hammond on February 15, 2009 at 3:05 pm
    //generate wave
    red = Math.sin(time*10);
    //normalise to 0 - 155
    rednorm = linear(red,-1,1,0,255);
    //rgba array
    [rednorm,255,255,255];
    Im having a little trouble with getting the RGBA values of a ‘fill’ effect to be controlled by a sine wave..
    I was hoping for the R value to peridically ramp from 0 to 255 smoothly, creating a smooth change in colour over time. (see my code below).
    Instead my fill colour stays white and flickers on cyan for a split second then goes straight back to white, with no smooth graduation in colour.
    Can’t get my head around why this shouldn’t work, but I am a newb to expressions so please excuse me!
    Filip Vandueren replied 17 years, 6 months ago 3 Members · 6 Replies
  • Filip Vandueren
    February 15, 2009 at 4:50 pm
    Hi John,
    The colors are expressed with 1 as maximum, not 255. So just change the code and it should work.
  • Paul Hennell
    February 15, 2009 at 8:09 pm
    Do you know why that is Filip? I encountered the same problem a week ago, trying to make a levels effect flash and eventually realised the input white had to be 0~1 not 0~255 like it says.
    It’s most confusing, I’m just wondering if there’s any logic behind it.
    Only in after effects do children get to pick and whip their parents.
    https://hennell-online.co.uk
  • Filip Vandueren
    February 16, 2009 at 12:06 am
    It’s just a convention I guess.
    Though from a programming perspective it does make sense: 0= off (black), 1=on (white).
    The accuracy with which you express inbetween values is arbitrary, 8 bits, 16 bits, 32 bits.
    What would happen if you work in 16 bits per channel, should you rewrite all your expressions to work with a maximum of 65535 ?
    You can choose to express all colors in After Effects as in the range 0-1 by setting the viewing preferences in the info palette.
    In 32 bpc mode, this is the standard way of expressing values, because values can also go below 0 and above 1. It’s easier to understand that 1.5 is 50% super-white than thinking what the hell a value of 21384161439 is 😉
  • John Hammond
    February 16, 2009 at 10:57 am
    Thank you all!
    I’ll try that when I get home. The was indeed very simple. It seems like it makes sense using 0 – 1 instead of 0 – 255, for the reasons you mentioned. Also, in this case, I can leave out the normalise line of code now.
    John
  • Paul Hennell
    February 16, 2009 at 5:47 pm
    Hadn’t thought of the advantages it brings to colour modes, it makes good sense when you explain that.
    Still, sensible though it may be, It could be more user friendly – you expect expressions to have to return the same value as the default option not something completely different…
    Thanks for the info though, always good to understand what’s going on.
  • Filip Vandueren
    February 16, 2009 at 10:57 pm
    You’ll still need the normalize, as negative values won’t make any sense.
