Activity Forums Adobe After Effects Expressions since i dont think we can script the swap…
  • Dan Ebberts
    June 21, 2007 at 12:53 am
    In CS3 .replaceSource() provides the Opt/Alt drag functionality.
    For previous versions, assuming your comp is active, the new footage is selected in the project window, and there is already a layer in your comp named “parent”, this should work:
    var myProject = app.project;
    var myComp = myProject.activeItem;
    var myNewLayer = myComp.layers.add(myProject.selection[0]);
    myNewLayer.threeDLayer = true;
    myNewLayer.parent = myComp.layer(“parent”);
    Dan
  • Danny Princz
    June 21, 2007 at 3:17 am
    i am soooo glad that was added.
    not sure if i can get this project to be done in CS3, but ill try the rest out
    thanks once again!
