Activity Forums Apple Final Cut Pro Legacy Simultaneous playback on external mon and cinema desktop
  • Jerry Hofmann
    February 3, 2006 at 2:59 pm
    loop the signal through the video monitor to the flat panel and you’ll need an adapter to do so I’d think. Decklink and AJA make the boxes I believe. Here’s the solution from AJA anyway: https://aja.com/hdp.htm
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
