Activity › Forums › AJA Video Systems › Simultaneous HD and SD Monitoring
  • Simultaneous HD and SD Monitoring
    Posted by Brent Streeper on January 16, 2006 at 7:15 pm
    Just wondering how to set up the Kona2 for simultaneous HD and SD monitoring. Is there a way to split the component signal out of the back of the K-Box? One going to an HDTV and one to an SD monitor?
    Brent
    Dual 2.5 G5, 6GB RAM, OS 10.4.2, Kona2 Card, K-Box.
    Walter Biscardi replied 20 years, 8 months ago 2 Members · 1 Reply
  • Walter Biscardi
    January 16, 2006 at 7:43 pm
    [Streep] “Just wondering how to set up the Kona2 for simultaneous HD and SD monitoring.”
    Feed the two signals via SDI and Component. Such as set up an HD Monitor with HD-SDI and an SD Monitor with Component SD. If your monitors only have Component inputs, get an AJA SDI to Component Converter.
    [Streep] “Is there a way to split the component signal out of the back of the K-Box? One going to an HDTV and one to an SD monitor?”
    Nope, you can only set the Component to feed a single format, either SD or HD. You can’t magically get two different formats out of one Component feed.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
