Activity Forums Apple Final Cut Pro Legacy Simultaneous Changes to multiple segments of text.
  • Simultaneous Changes to multiple segments of text.
    Posted by Riccardo Zito on April 7, 2005 at 1:25 pm
    Hello all,
    I would like to make size and font changes to multiple segments of text in final cut pro 4.5.. all in one go.
    I tried selecting them all and doing the changes, alas to no avail.
    I dearly hope one of you knows of a way.. as I really don’t want to spend my hole life making corrections.
    I thank you,
    El Desperado
    Rienk Leendertse replied 21 years, 5 months ago 4 Members · 4 Replies
  • Kevin Monahan
    April 7, 2005 at 5:21 pm
    Nope. You have to do them one at a time. BTW, I suggest using Title 3D and not the legacy title generators. The quality and control is much better. Title 3D’s on the install disk in the Extras folder.
    Kevin Monahan
    Author – Motion Graphics and Effects in Final Cut Pro
    fcpworld.com
  • David Bogie
    April 7, 2005 at 6:16 pm
    Not that it helps at the moment but, Kevin, let’s say he uses a Boris font tool and chooses a style from the palette. Can you make a change to that style and have it go global? Seems we did that once back in the Olden Media 100 Days with the original Graffiti but I may be fantasizing?
    We did save ourselves a ton of trouble on a project last year with some preplanning. We KNEW the clients would change their minds many times on fonts and colors. We designed the lower thirds and other text in PowerPoint. All we did was change the master slides and reimport. The only reason it worked was careful planning.
    bogiesan
  • Kevin Monahan
    April 7, 2005 at 6:24 pm
    Bog,
    He’s gonna have to touch every single text generator regardless of using Title 3D or not. However, I’d just change one of ’em, do a Replace Edit on all of ’em in rapid fire. Then I’d go back in and merely change the text. Changing one thing is faster than changing 4 things.
    What you’re talking about sounds like a feature request. Unfortunately.
    Kevin Monahan
    fcpworld.com
  • Rienk Leendertse
    April 8, 2005 at 8:14 pm
    I think you could consider exporting as XML.
    Open the XML in a text editor and just do a ‘replace all’ for the specific text.
    Save as plain textfile (with the .xml extension)
    and re-import in FCP…
    Rienk
