Activity Forums Adobe After Effects Simulating the light of a flickering fire
  • Simulating the light of a flickering fire
    Posted by Jack Hilkewich on June 16, 2005 at 11:30 pm
    Hello,
    I was wondering if there was a way to simulate the light that is given off of by a fire? Flickering and such. I have created a fire in Maya against a alpha BG and I am incorporating it into some video footage. I would like to add the glow from the fire onto the video.
    Any suggestions would be great.
    I am using 6.5
    Jack Hilkewich replied 21 years, 3 months ago 4 Members · 6 Replies
  • N. Row
    June 16, 2005 at 11:39 pm
    Try using the “Wiggler” with the “jagged” pop-up on a matted solids transparency with an “Add” math operator on the layer. Otherwise, just keyframe the opacity and copy-paste the keys as flickery as you can.
  • Jack Hilkewich
    June 17, 2005 at 12:15 am
    I got most of that but what is a “add Math operator”? Sorry I’ve been using AE for a while and just now have really started to concentrate on the more in depth stuff.
  • Rob Montague
    June 17, 2005 at 1:03 am
  • Jack Hilkewich
    June 17, 2005 at 1:53 am
    Thanks so much I will try some of the suggestions!
  • Don Jaksa
    June 17, 2005 at 5:28 pm
    Bypassing all of the fancy techie mumbo-jumbo, the post from Serge just has you duplicating your flame layer (your maya fire), turn on 3D layer, and create a light which uses that duplicate layer as the projection map. You will probably want to move the layer forward in Z space to get it out of the field of view of your comp as well as to widen the area that the projection hits. (note: in order for your BKG and other layers to receive the projected light, you will need to turn on their 3D switch as well).
    It’s a cool idea because it will mimic the exact movement of your fire/flame. Wish it had been my idea.
    DJ
  • Jack Hilkewich
    June 17, 2005 at 8:36 pm
    Thanks for this tip too! I will be trying this out within the next few days .
    Cheers
