Activity › Forums › Apple Final Cut Pro Legacy › Simulating handheld camera!
Posted by Per Rönnecke on August 27, 2005 at 6:57 amDoes anyone now if there is a plugin for FCP that simulates the movements of a handheld camera?
/Per
Mark Landman replied 21 years, 1 month ago 5 Members · 6 Replies -
Andy Mees
August 27, 2005 at 2:46 pmi’ve not tried this one, but it is a free download and if you could slow it and smooth it, then it might do th trick
https://www.riverrockstudios.com/riverrock/pages/jitterbug.html
if you go over to https://proapptips.com you’ll find a pretty comprehensive list of the plugins avilable for fcp
hope it helps
Andy -
Per Rönnecke
August 27, 2005 at 3:45 pmThanks Andy. I will try that and give you my opinion. And thanks for the link.
And David, maybe the seen is already shot or maybe it’s a green screen shot and you want to “shake” both foreground and background simultaneously to improve the live feeling.
I’ve tried some motion editing in FCP, but it always ends up quite static.
/Per
Graeme Nattress
August 27, 2005 at 3:50 pm“G Earthquaker” in Set 2 can be set to fake bad camerawork. Try out the demo at http://www.nattress.com and see.
Graeme
– http://www.nattress.com – Film Effects and Standards Conversion for FCP
Per Rönnecke
August 27, 2005 at 4:07 pmThanks, Graham!
That’s typical! I have your Film Presets, Set 1 and G Free, not Set 2!! 🙂 I’ll try out the demo!
/Per
Mark Landman
August 28, 2005 at 6:44 pmTry using the motion stabilize filter on a handheld shot then apply the keyframes that are generated to the shot you want to shake. You’ll need to scale the size of the frame up a little to cover up the ratty edges.
Mark Landman
PM Productions
Champaign, IL
