Activity Forums Apple Final Cut Pro Legacy simulate handheld
  • simulate handheld
    Posted by Aaron Metchik on April 20, 2008 at 2:28 am
    I know that the smoothcam feature can stabilize a hand held shot, but is there a similarly quick method of taking a shot from a tripod and simulating a little shake of a hand held shot?
    In my project I have to match some handheld shots with their reverse shots which were shot on a tripod.
    I have fiddled around with the motion tab, zooming in about 5 percent on the static shots, then adding keyframes throughout the shot and adjusting the “center” on each keyframe, which can give it the unsteady movement of a hand held shot. Sometimes I get really good results but it’s very difficult and time consuming to get it to look right. It occurred to me that this might be a function that lots of people wanted and therefore there might be a built in effect that achieves this but I haven’t been able to find anything like that in the manual. Anyone know of one or have any pointers on how to achieve that look easier or better?
    Tom Brooks replied 18 years, 4 months ago 2 Members · 2 Replies
  • Tom Brooks
    April 20, 2008 at 10:22 am
    In Motion 3 under Behaviors you’ll find something called Wriggle. This adds motion to an object. I believe you can set it up in a way that the motion is random. I’ve used it to add flicker to lights and lens flares, but haven’t tried it to add motion to a regular layer.
  • Tom Brooks
    April 20, 2008 at 11:45 am
    Maybe the parameter behavior “Randomize” is closer to what you want.
