Activity Forums Adobe After Effects Simulate analogue signal switch (?)
  • Simulate analogue signal switch (?)
    Posted by Tom Carter on May 5, 2006 at 6:04 pm
    As you can proabably tell from the title, I don’t really know what the technical name is for what I’m trying to achieve. I’m trying to simulate some surveillance footage and want to make the cuts between scenes look as if the user is manually switching between different input signals (as if from different cameras).
    I think what I need to go for is some sort of combination of distortion/vertical hold/overlaying (?), but I’ve got no way to set any hardware like this up and see how it should really look. If anyone can recommend any techniques/ filters, or any footage where I could see this in action, that would be much appreciated,
    Cheers,
    Tom
    http://www.crate20.co.uk
    Juan Obregon replied 20 years, 3 months ago 2 Members · 1 Reply
