Activity Forums Apple Motion Simulate a Projector
  • Simulate a Projector
    Posted by Thomas Imbrigiotta on September 11, 2010 at 4:20 am
    I’m trying to simulate an old school projector on footage of a factory wall. This is a political ad so I can’t post a reference file. Basically, our candidate gives a line to camera in an abandoned factory then the camera pans to a grungy wall. On this wall I hope to simulate a projection of a clip of our opposition candidate delivering a line about outsourcing jobs (you know – widely out of context – typical political spot).
    Right now I have the clip in final cut using an overlay blend mode. I also have the bad tv filter tweaking around to simulate a slight waviness.
    I’m looking for any advice to add to the overall look of this effect.
    I’ve found some simulations on YouTube that MIGHT work:
    This clip seems like it’s got some nice qualities (although, I’m not going to actually show the projector itself). I like the slightly moving screen and the flickering light.
    https://www.youtube.com/watch?v=A2oaPPqrqH8&feature=related
    I’m thinking that some combination of a blend mode and animating a solid matte to luma key through might be the way. What do you guys think?
    Thanks in advance for the help.
    -T.J.
    T.J. Imbrigiotta
    Envision Communications, Inc.
    Washington DC
    https://envisioncommunicationsinc.com
    Mac Pro
    2 x 3.2GHz Quad Core Intel Xeon
    6GB RAM
    AJA Kona LHe
    OS 10.6.4
    Stephen Smith replied 16 years ago 4 Members · 3 Replies
  • Andy Neil
    September 11, 2010 at 4:58 pm
    I doubt a luma key is necessary at all. You can simulate the frame with a simple mask and a bit of feather.
    Everything else can be simulated using the Bad Film filter (it’s right above the Bad TV filter).
    https://www.timesavertutorials.com
  • Gareth Randall
    September 14, 2010 at 10:50 pm
    Just as a couple of extra ideas, I find that using a shape to create a “hot spot” in the middle of the projector screen helps to sell the effect, as does using a wriggle behaviour on the opacity (just a small amount).
  • Stephen Smith
    September 15, 2010 at 5:32 pm
    Keep in mind that old film was shot on 24 frames per second or less. The 30 second frame rate really does feel different then 24. When you shoot the footage that you will make look old keep that in mind.
    Stephen Smith
    Utah Video Productions
    Check out my Motion Tutorials
