Activity › Forums › Adobe After Effects › Simply animate a mask ?
Posted by Martijn Merkelbag on June 23, 2007 at 10:45 amHi there !
Im sure this must be a pretty simply question…..
But how can i simply animate a mask ?
Greetings Martijn M !
Martijn Merkelbag replied 19 years, 3 months ago 3 Members · 3 Replies -
Jacob Wessler
June 23, 2007 at 3:37 pmStart with your source (picture, video, solid)
Add your mask.
Twirl down your options (or hit MM in quick succession to show all the mask options)
Place a keyframe at the start of your animation
Move the playhead to another point in time
Change the shape of your maskMake sure to lock all other layers so you don’t accidentally move one of them. You can also double-click your layer to open it in its own window and work on the mask there. Set up a side-by-side with your layer footage in one windown and your composition in the other and you can see (in real time) how chaning your mask will change your final result.
Repeat for as many keyframes as you need!
Jacob
Martijn Merkelbag
June 23, 2007 at 7:18 pmThanks for the help guys !
I just made some very stupid mistake that did not make it animate.
Its all working now !Thanks again.
greets, Martijn M
