Activity Forums Web Design (WordPress, Joomla, etc.) Simplifing the Web Design Process
  • Simplifing the Web Design Process
    Posted by Amy Martin on February 2, 2009 at 3:19 pm
    Currently I am publishing newsletters on the web for my employer, and I feel like there is a better more efficient process out there rather than the one that I am using. Any opinions would be greatly appreciated.
    Right now, I design the newsletter in Publisher, and print to get the pdf version. Then I take the text and format at into Dreamweaver to put it on the web. Then I take the text and format into PHP to send the newsletter out.
    I guess the problem I have come across most often is that I have to take the text back to a notepad everytime because the formating between programs doesnt seem to talk.
    In college I used a mac with Dreamweaver and I remember it being efficient, but not sure if it would be worth the cost to buy a new computer or a new program.
    Like I said any opinions would be appreciated.
    Thank you.
    Mike Smith replied 17 years, 7 months ago 3 Members · 3 Replies
  • Fernando Mol
    February 2, 2009 at 8:04 pm
    Why are you making a PDF?
    I used to send mail invitations for an art gallery. Here is a look at the process I used to do. I hope this can help.
    1.They make a design for print.
    2.I receive a PDF version.
    3.Made an HTML adaptation in Dreamweaver.
    4.Upload the images to a server.
    5.Fix the links to the images, if needed.
    6.Insert the HTML into Outlook.
    7.Send the email.
    8.Pray for the users to have their “view HTML content” option selected.
  • Mike Smith
    February 5, 2009 at 4:54 pm
    Why couldn’t you use the html as formatted in dreamweaver in your php – maybe using an echo – three left angle brackets – EOT type construction ?
  • Mike Smith
    February 6, 2009 at 11:22 am
    Or even try a direct include – pull the html into a php variable and echo it, using something like
    ob_start();
    include(‘file.php’);
    $content = ob_get_clean();
    from
    https://www.codingforums.com/archive/index.php/t-124537.html
    or
    ob_start(); // start buffer
    include (“file-to-include.php”);
    $content = ob_get_contents(); // assign buffer contents to variable
    ob_end_clean(); // end buffer and remove buffer contents
    echo $content;
    from
    https://www.acuras.co.uk/articles/88-php-include-a-file-and-store-contents-to-variable-using-output-buffer
