Simple? BCC plus Avid Question
Posted by Dahmooser on February 23, 2007 at 10:07 pmI’ve created two filler layers in Avid MC and applied a Lens Flare Advanced Effect to them.
When I export a QT reference, all I get is black video.
Why is this? In Avid, must their be video underneath? And what if I want the Lens Flare Effect to include an Alpha so that I can use it with transparency in After Effects?I apologize for the rather simple question, but one must start somewhere, right?
Any suggestions would be greatly appreciated!
Respectfully,
Ryan
Dahmooser replied 19 years, 6 months ago 2 Members · 4 Replies -
Peter Mcauley
February 26, 2007 at 4:57 pmHi,
This sounds like an OpenGl related issue. Can you please send me the versions of the Avid MC and BCC along with the machine specs that you are using please? Once I have that information I’ll bring this to our engineering dept to see if they understand why this is happening.
Peter.
Dahmooser
February 26, 2007 at 5:00 pmPeter,
Thanks for the reply. I am in class all this week from 9-6pm, so I’ll gather this information when i get home. I know that BCC is 4.1 and MC is 2.6.2.
Ryan
Dahmooser
February 28, 2007 at 4:38 amPeter,
Turns out, I downloaded and burned MC version 2.6.3 and .4 but never installed them. I now remember reading that Boris Filters are broken in 2.6.4 in an Avid forum thread, and backed away. Can you validate this?
SO, I have VERSION 2.6.0.
I have BCC 4.1, will they stop working under 2.6.4?Currently I am not having any serious issues with 2.6, but I know some Avid issues do exist.
I will switch to my other Avid PC, to post the DXDiag information.
Ryan
Dahmooser
February 28, 2007 at 4:41 amDX DIAG INFO:
System Information
Time of this report: 2/27/2007, 20:24:28
Machine name: AVIDSYSTEM
Operating System: Windows XP Professional (5.1, Build 2600) Service Pack 2 (2600.xpsp_sp2_gdr.050301-1519)
Language: English (Regional Setting: English)
System Manufacturer: ASUSTEK COMPUTER INC
System Model: P5W DH Deluxe
BIOS: BIOS Date: 08/28/06 21:35:13 Ver: 08.00.12
Processor: Intel(R) Core(TM)2 CPU 6600 @ 2.40GHz (2 CPUs)
Memory: 3072MB RAM
Page File: 194MB used, 4799MB available
Windows Dir: C:\WINDOWS
DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
DxDiag Version: 5.03.2600.2180 32bit Unicode————
DxDiag Notes
DirectX Files Tab: No problems found.
Display Tab 1: No problems found.
Display Tab 2: No problems found.
Sound Tab 1: No problems found.
Music Tab: No problems found.
Input Tab: No problems found.
Network Tab: No problems found.——————–
DirectX Debug Levels
Direct3D: 0/4 (n/a)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (n/a)
DirectMusic: 0/5 (n/a)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)—————
Display Devices
Card name: NVIDIA Quadro FX 1500
Manufacturer: NVIDIA
Chip type: Quadro FX 1500
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_029E&SUBSYS_032C10DE&REV_A1
Display Memory: 256.0 MB
Current Mode: 1280 x 1024 (32 bit) (60Hz)
Monitor: Plug and Play Monitor
Monitor Max Res: 1600,1200
Driver Name: nv4_disp.dll
Driver Version: 6.14.0010.9136 (English)
DDI Version: 9 (or higher)
Driver Attributes: Final Retail
Driver Date/Size: 7/12/2006 12:19:00, 4493568 bytes
WHQL Logo’d: Yes
WHQL Date Stamp: n/a
VDD: n/a
Mini VDD: nv4_mini.sys
Mini VDD Date: 7/12/2006 12:19:00, 3934592 bytes
Device Identifier: {D7B71E3E-41DE-11CF-DE50-262300C2CB35}
Vendor ID: 0x10DE
Device ID: 0x029E
SubSys ID: 0x032C10DE
Revision ID: 0x00A1
Revision ID: 0x00A1
Video Accel: ModeMPEG2_A ModeMPEG2_B ModeMPEG2_C ModeMPEG2_D ModeWMV9_B ModeWMV9_A
Deinterlace Caps: {212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
{212DC724-3235-44A4-BD29-E1652BBCC71C}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
{335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
Registry: OK
DDraw Status: Enabled
D3D Status: Enabled
AGP Status: Enabled
DDraw Test Result: Not run
D3D7 Test Result: Not run
D3D8 Test Result: Not run
D3D9 Test Result: Not runCard name: NVIDIA Quadro FX 1500
Current Mode: 1600 x 1200 (32 bit) (60Hz)
WHQL Logo’d: Yes
VDD: n/a
Vendor ID: 0x10DE
Device ID: 0x029E
Revision ID: 0x00A1
Revision ID: 0x00A1
Registry: OK
D3D Status: Enabled
AGP Status: Enabled
D3D9 Test Result: Not run————-
Sound Devices
Description: Realtek HD Audio output
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_0882&SUBSYS_1043E601&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RtkHDAud.sys
Driver Version: 5.10.0000.5247 (English)
WHQL Logo’d: Yes
Date and Size: 4/17/2006 00:31:26, 4262912 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
HW Accel Level: Full
Cap Flags: 0xF5F
Min/Max Sample Rate: 8000, 192000
Static/Strm HW Mix Bufs: 33, 32
Static/Strm HW 3D Bufs: 33, 32
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: Yes, Yes
I3DL2(tm) Listen/Src: Yes, Yes
Sensaura(tm) ZoomFX(tm): No
Registry: OK
Sound Test Result: Not run———————
Sound Capture Devices
Description: Realtek HD Audio input
Default Sound Capture: Yes
Default Voice Capture: Yes
Cap Flags: 0x41
Format Flags: 0xFFF———–
DirectMusic
DLS Path: C:\WINDOWS\SYSTEM32\drivers\GM.DLS
DLS Version: 1.00.0016.0002
Acceleration: n/a
Ports: Microsoft Synthesizer, Software (Not Kernel Mode), Output, DLS, Internal, Default Port
Microsoft MIDI Mapper [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Microsoft GS Wavetable SW Synth [Emulated], Hardware (Not Kernel Mode), Output, No DLS, Internal
Registry: OK
Test Result: Not run——————-
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/aDevice Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/aPoll w/ Interrupt: No
Registry: OK———–
USB Devices
+ USB Root Hub
| Vendor/Product ID: 0x8086, 0x27CB
| Matching Device ID: usb\root_hub
| Service: usbhub
| Driver: usbhub.sys, 8/3/2004 22:08:44, 57600 bytes
| Driver: usbd.sys, 8/4/2004 04:00:00, 4736 bytes—————-
Gameport Devices
PS/2 Devices
+ Standard 101/102-Key or Microsoft Natural PS/2 Keyboard
| Matching Device ID: *pnp0303
| Service: i8042prt
| Driver: i8042prt.sys, 8/4/2004 04:00:00, 52736 bytes
| Driver: kbdclass.sys, 8/4/2004 04:00:00, 24576 bytes
+ Terminal Server Keyboard Driver
| Matching Device ID: root\rdp_kbd
| Upper Filters: kbdclass
| Service: TermDD
| Driver: termdd.sys, 8/4/2004 00:01:08, 40840 bytes
+ Microsoft PS/2 Mouse
| Matching Device ID: *pnp0f03
| Service: i8042prt
| Driver: mouclass.sys, 8/4/2004 04:00:00, 23040 bytes
+ Terminal Server Mouse Driver
| Matching Device ID: root\rdp_mou
| Upper Filters: mouclass
| Service: TermDD
| Driver: mouclass.sys, 8/4/2004 04:00:00, 23040 bytes—————————-
DirectPlay Service Providers
DirectPlay8 Modem Service Provider – Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 Serial Service Provider – Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 IPX Service Provider – Registry: OK, File: dpnet.dll (5.03.2600.2180)
DirectPlay8 TCP/IP Service Provider – Registry: OK, File: dpnet.dll (5.03.2600.2180)
Internet TCP/IP Connection For DirectPlay – Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
IPX Connection For DirectPlay – Registry: OK, File: dpwsockx.dll (5.03.2600.2180)
Modem Connection For DirectPlay – Registry: OK, File: dpmodemx.dll (5.03.2600.2180)
Serial Connection For DirectPlay – Registry: OK, File: dpmodemx.dll (5.03.2600.2180)DirectPlay Voice Wizard Tests: Full Duplex: Not run, Half Duplex: Not run, Mic: Not run
DirectPlay Test Result: Not run
Registry: OK——————-
DirectPlay Adapters
DirectPlay8 Serial Service Provider: COM1
DirectPlay8 TCP/IP Service Provider: Local Area Connection 2 – IPv4 –———————–
DirectPlay Voice Codecs
Voxware VR12 1.4kbit/s
Voxware SC06 6.4kbit/s
Voxware SC03 3.2kbit/s
MS-PCM 64 kbit/s
MS-ADPCM 32.8 kbit/s
Microsoft GSM 6.10 13 kbit/s
TrueSpeech(TM) 8.6 kbit/s————————-
DirectPlay Lobbyable Apps
Disk & DVD/CD-ROM Drives
Drive: C:
Free Space: 127.9 GB
Total Space: 152.6 GB
File System: NTFS
Model: WDC WD1600JS-88MHB0Drive: E:
Free Space: 162.0 GB
Total Space: 239.4 GB
File System: NTFS
Model: WDC WD2500YS-01SHB0Drive: F:
Free Space: 65.6 GB
File System: NTFS
Model: WDC WD2500YS-01SHB0Drive: D:
Model: SONY DVD RW DW-Q120A
Driver: c:\windows\system32\drivers\cdrom.sys, 5.01.2600.2180 (English), 8/4/2004 04:00:00, 49536 bytes————–
System Devices
Name: Intel(R) 82801GR/GH/GHM (ICH7 Family) PCI Express Root Port – 27E0
Device ID: PCI\VEN_8086&DEV_27E0&SUBSYS_00000000&REV_01\3&11583659&0&E4
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytesName: Intel(R) 82801G (ICH7 Family) Ultra ATA Storage Controllers – 27DF
Device ID: PCI\VEN_8086&DEV_27DF&SUBSYS_81791043&REV_01\3&11583659&0&F9
Driver: C:\WINDOWS\system32\DRIVERS\pciide.sys, 5.01.2600.0000 (English), 8/17/2001 12:51:52, 3328 bytes
Driver: C:\WINDOWS\system32\DRIVERS\pciidex.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:42, 25088 bytes
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:44, 95360 bytesName: Intel(R) 82801G (ICH7 Family) SMBus Controller – 27DA
Device ID: PCI\VEN_8086&DEV_27DA&SUBSYS_81791043&REV_01\3&11583659&0&FB
Driver: n/aName: Microsoft UAA Bus Driver for High Definition Audio
Device ID: PCI\VEN_8086&DEV_27D8&SUBSYS_81D81043&REV_01\3&11583659&0&D8
Driver: C:\WINDOWS\system32\DRIVERS\hdaudbus.sys, 5.10.0001.5013 (English), 1/7/2005 16:07:18, 138752 bytesName: Intel(R) 82801G (ICH7 Family) PCI Express Root Port – 27D6
Device ID: PCI\VEN_8086&DEV_27D6&SUBSYS_00000000&REV_01\3&11583659&0&E3
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytesName: Intel(R) 82801G (ICH7 Family) PCI Express Root Port – 27D0
Device ID: PCI\VEN_8086&DEV_27D0&SUBSYS_00000000&REV_01\3&11583659&0&E0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytesName: Intel(R) 82801G (ICH7 Family) USB2 Enhanced Host Controller – 27CC
Device ID: PCI\VEN_8086&DEV_27CC&SUBSYS_81791043&REV_01\3&11583659&0&EF
Driver: C:\WINDOWS\system32\drivers\usbehci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 26624 bytes
Driver: C:\WINDOWS\system32\drivers\usbport.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 142976 bytes
Driver: C:\WINDOWS\system32\usbui.dll, 5.01.2600.2180 (English), 8/3/2004 23:56:48, 74240 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytes
Driver: C:\WINDOWS\system32\hccoin.dll, 5.01.2600.2180 (English), 8/4/2004 04:00:00, 7168 bytesName: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller – 27CB
Device ID: PCI\VEN_8086&DEV_27CB&SUBSYS_81791043&REV_01\3&11583659&0&EB
Driver: C:\WINDOWS\system32\drivers\usbuhci.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:38, 20480 bytes
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytesName: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller – 27CA
Device ID: PCI\VEN_8086&DEV_27CA&SUBSYS_81791043&REV_01\3&11583659&0&EA
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytesName: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller – 27C9
Device ID: PCI\VEN_8086&DEV_27C9&SUBSYS_81791043&REV_01\3&11583659&0&E9
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytesName: Intel(R) 82801G (ICH7 Family) USB Universal Host Controller – 27C8
Device ID: PCI\VEN_8086&DEV_27C8&SUBSYS_81791043&REV_01\3&11583659&0&E8
Driver: C:\WINDOWS\system32\drivers\usbhub.sys, 5.01.2600.2180 (English), 8/3/2004 22:08:44, 57600 bytesName: Intel(R) 82801GB/GR/GH (ICH7 Family) Serial ATA Storage Controller – 27C0
Device ID: PCI\VEN_8086&DEV_27C0&SUBSYS_26011043&REV_01\3&11583659&0&FA
Driver: C:\WINDOWS\system32\DRIVERS\atapi.sys, 5.01.2600.2180 (English), 8/3/2004 21:59:44, 95360 bytesName: Intel(R) 82801GB/GR (ICH7 Family) LPC Interface Controller – 27B8
Device ID: PCI\VEN_8086&DEV_27B8&SUBSYS_00000000&REV_01\3&11583659&0&F8
Driver: C:\WINDOWS\system32\DRIVERS\isapnp.sys, 5.01.2600.0000 (English), 8/17/2001 12:58:02, 35840 bytesName: Intel(R) 975X PCI Express Root Port Device ID: PCI\VEN_8086&DEV_277D&SUBSYS_00000000&REV_C0\3&11583659&0&08
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytesName: Intel(R) 975X Memory Controller Hub – 277C
Device ID: PCI\VEN_8086&DEV_277C&SUBSYS_00000000&REV_C0\3&11583659&0&00
Driver: n/aName: Intel(R) 82801 PCI Bridge – 244E
Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_E1\3&11583659&0&F0
Driver: C:\WINDOWS\system32\DRIVERS\pci.sys, 5.01.2600.2180 (English), 8/3/2004 22:07:48, 68224 bytesName: Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller #2
Device ID: PCI\VEN_11AB&DEV_4362&SUBSYS_81421043&REV_20\4&AD17F01&0&00E3
Driver: C:\WINDOWS\system32\DRIVERS\yk51x86.sys, 8.24.0003.0003 (English), 3/30/2005 07:24:00, 230400 bytesName: Marvell Yukon 88E8053 PCI-E Gigabit Ethernet Controller
Device ID: PCI\VEN_11AB&DEV_4362&SUBSYS_81421043&REV_20\4&8D68EE5&0&00E4
Driver: C:\WINDOWS\system32\DRIVERS\yk51x86.sys, 8.24.0003.0003 (English), 3/30/2005 07:24:00, 230400 bytesName: NVIDIA Quadro FX 1500
Device ID: PCI\VEN_10DE&DEV_029E&SUBSYS_032C10DE&REV_A1\4&31F3E1F0&0&0008
Driver: C:\WINDOWS\system32\DRIVERS\nv4_mini.sys, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 3934592 bytes
Driver: C:\WINDOWS\system32\nv4_disp.dll, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 4493568 bytes
Driver: C:\WINDOWS\system32\nvsvc32.exe, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 155715 bytes
Driver: C:\WINDOWS\system32\nvhwvid.dll, 6.14.0010.9136 (), 7/12/2006 12:19:00, 581632 bytes
Driver: C:\WINDOWS\system32\nvapi.dll, 6.14.0010.9136 (), 7/12/2006 12:19:00, 196608 bytes
Driver: C:\WINDOWS\system32\nvoglnt.dll, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 5632000 bytes
Driver: C:\WINDOWS\system32\nvcpl.dll, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 7626752 bytes
Driver: C:\WINDOWS\system32\nvmctray.dll, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 86016 bytes
Driver: C:\WINDOWS\system32\nvwddi.dll, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 81920 bytes
Driver: C:\WINDOWS\system32\nvnt4cpl.dll, 6.14.0010.11044 (English), 7/12/2006 12:19:00, 286720 bytes
Driver: C:\WINDOWS\system32\nvmccs.dll, 6.14.0010.9136 (English), 7/12/2006 12:19:00, 229376 bytes
Driver: C:\WINDOWS\help\nvcpl.hlp, 7/12/2006 12:19:00, 177897 bytes
Driver: C:\WINDOWS\help\nvwcplen.hlp, 7/12/2006 12:19:00, 55444 bytes
Driver: C:\WINDOWS\system32\nvcod.dll, 1.00.0000.0035 (English), 7/12/2006 12:19:00, 35840 bytes
Driver: C:\WINDOWS\system32\nvcodins.dll, 1.00.0000.0035 (English), 7/12/2006 12:19:00, 35840 bytesName: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8025&SUBSYS_702A14DB&REV_01\4&CF81C54&0&08F0
Driver: C:\WINDOWS\system32\DRIVERS\ohci1394.sys, 5.01.2600.2180 (English), 8/4/2004 04:00:00, 61056 bytes
Driver: C:\WINDOWS\system32\DRIVERS\1394bus.sys, 5.01.2600.2180 (English), 8/4/2004 04:00:00, 53248 bytes
Driver: C:\WINDOWS\system32\DRIVERS\nic1394.sys, 5.01.2600.2180 (English), 8/4/2004 04:00:00, 61824 bytes
Driver: C:\WINDOWS\system32\DRIVERS\arp1394.sys, 5.01.2600.2180 (English), 8/4/2004 04:00:00, 60800 bytes
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 05:46:40, 6400 bytesName: Texas Instruments OHCI Compliant IEEE 1394 Host Controller
Device ID: PCI\VEN_104C&DEV_8023&SUBSYS_815B1043&REV_00\4&CF81C54&0&18F0
Driver: C:\WINDOWS\system32\DRIVERS\enum1394.sys, 5.01.2600.0000 (English), 8/17/2001 05:46:40, 6400 bytes——————
DirectX Components
ddraw.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 266240 bytes
ddrawex.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 27136 bytes
dxapi.sys: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 10496 bytes
d3d8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 1179648 bytes
d3d8thk.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 8192 bytes
d3d9.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 1689088 bytes
d3dim.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 436224 bytes
d3dim700.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 825344 bytes
d3dramp.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 590336 bytes
d3drm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 350208 bytes
d3dxof.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 47616 bytes
d3dpmesh.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 34816 bytes
dplay.dll: 5.00.2134.0001 English Final Retail 8/4/2004 04:00:00 33040 bytes
dplayx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 229888 bytes
dpmodemx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 23552 bytes
dpwsock.dll: 5.00.2134.0001 English Final Retail 8/4/2004 04:00:00 42768 bytes
dpwsockx.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 57344 bytes
dplaysvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 30208 bytes
dpnsvr.exe: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 18432 bytes
dpnet.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 375296 bytes
dpnlobby.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 3584 bytes
dpnaddr.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 3584 bytes
dpvoice.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 212480 bytes
dpvsetup.exe: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 83456 bytes
dpvvox.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 116736 bytes
dpvacm.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 21504 bytes
dpnhpast.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 35328 bytes
dpnhupnp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 60928 bytes
dpserial.dll: 5.00.2134.0001 English Final Retail 8/4/2004 04:00:00 53520 bytes
dinput.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 159232 bytes
dinput8.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 181760 bytes
dimap.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 44032 bytes
diactfrm.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 394240 bytes
joy.cpl: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 68608 bytes
gcdef.dll: 5.01.2600.0000 English Final Retail 8/4/2004 04:00:00 76800 bytes
pid.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 35328 bytes
dsound.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 367616 bytes
dsound3d.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 1294336 bytes
dswave.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 19456 bytes
dsdmo.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 181760 bytes
dsdmoprp.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 71680 bytes
dmusic.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 104448 bytes
dmband.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 28672 bytes
dmcompos.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 61440 bytes
dmime.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 181248 bytes
dmloader.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 35840 bytes
dmstyle.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 105984 bytes
dmsynth.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 103424 bytes
dmscript.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 82432 bytes
system.dll: 1.01.4322.2032 English Final Retail 9/26/2006 14:00:19 1224704 bytes
dx7vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 619008 bytes
dx8vb.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 1227264 bytes
dxdiagn.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 2113536 bytes
mfc40.dll: 4.01.0000.6140 English Final Retail 8/4/2004 04:00:00 924432 bytes
mfc42.dll: 6.02.4131.0000 English Final Retail 8/4/2004 04:00:00 1028096 bytes
wsock32.dll: 5.01.2600.2180 English Final Retail 8/4/2004 04:00:00 22528 bytes
amstream.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 70656 bytes
devenum.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 59904 bytes
dxmasf.dll: 6.04.0009.1133 English Final Retail 8/22/2006 04:05:26 498742 bytes
mciqtz32.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 35328 bytes
mpg2splt.ax: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 148992 bytes
msdmo.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 14336 bytes
encapi.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 20480 bytes
qasf.dll: 10.00.0000.3646 English Final Retail 8/11/2004 00:45:04 221184 bytes
qcap.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 192512 bytes
qdv.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 279040 bytes
qdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 385024 bytes
qedit.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 562176 bytes
qedwipes.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 733696 bytes
quartz.dll: 6.05.2600.2749 English Final Retail 8/29/2005 19:54:26 1287168 bytes
strmdll.dll: 4.01.0000.3936 English Final Retail 8/21/2006 09:52:08 246814 bytes
iac25_32.ax: 2.00.0005.0053 English Final Retail 8/4/2004 04:00:00 199680 bytes
ir41_32.ax: 4.51.0016.0003 English Final Retail 8/4/2004 04:00:00 848384 bytes
ir41_qc.dll: 4.30.0062.0002 English Final Retail 8/4/2004 04:00:00 120320 bytes
ir41_qcx.dll: 4.30.0064.0001 English Final Retail 8/4/2004 04:00:00 338432 bytes
ir50_32.dll: 5.2562.0015.0055 English Final Retail 8/4/2004 04:00:00 755200 bytes
ir50_qc.dll: 5.00.0063.0048 English Final Retail 8/4/2004 04:00:00 200192 bytes
ir50_qcx.dll: 5.00.0064.0048 English Final Retail 8/4/2004 04:00:00 183808 bytes
ivfsrc.ax: 5.10.0002.0051 English Final Retail 8/4/2004 04:00:00 154624 bytes
mswebdvd.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 204288 bytes
ks.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:15:22 140928 bytes
ksproxy.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 130048 bytes
ksuser.dll: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:44 4096 bytes
stream.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:08:04 48640 bytes
mspclock.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:40 5376 bytes
mspqm.sys: 5.01.2600.2180 English Final Retail 8/3/2004 21:58:42 4992 bytes
mskssrv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:42 7552 bytes
swenum.sys: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 4352 bytes
mstee.sys: 5.03.2600.2180 English Final Retail 8/3/2004 21:58:40 5504 bytes
ipsink.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 16384 bytes
mpeg2data.ax: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 118272 bytes
ndisip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 10880 bytes
streamip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:14 15360 bytes
msvidctl.dll: 6.05.2600.2180 English Final Retail 8/4/2004 04:00:00 1428480 bytes
slip.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 11136 bytes
nabtsfec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:30 85376 bytes
ccdecode.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:18 17024 bytes
vbisurf.ax: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 30720 bytes
msyuv.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 17408 bytes
kstvtune.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 61952 bytes
ksxbar.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 43008 bytes
kswdmcap.ax: 5.03.2600.2180 English Final Retail 8/3/2004 23:56:58 90624 bytes
vfwwdm32.dll: 5.01.2600.2180 English Final Retail 8/3/2004 23:56:48 53760 bytes
wstcodec.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:22 19328 bytes
wstdecod.dll: 5.03.2600.2180 English Final Retail 8/4/2004 04:00:00 50688 bytes
msdv.sys: 5.03.2600.2180 English Final Retail 8/3/2004 22:10:00 51328 bytes——————
DirectShow Filters
——————WDM Streaming VBI Codecs:
NABTS/FEC VBI Codec,0x00200000,2,1,,5.03.2600.2180
CC Decoder,0x00200000,2,1,,5.03.2600.2180
WST Codec,0x00200000,1,1,,5.03.2600.2180DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,,
WMAPro over S/PDIF DMO,0x00600800,1,1,,
WMSpeech Decoder DMO,0x00600800,1,1,,
WMVideo Advanced Decoder DMO,0x00800001,1,1,,
Mpeg4s Decoder DMO,0x00800001,1,1,,
WMV Screen decoder DMO,0x00800001,1,1,,
WMVideo Decoder DMO,0x00800001,1,1,,
Mpeg43 Decoder DMO,0x00800001,1,1,,
Mpeg4 Decoder DMO,0x00800001,1,1,,
Nero Audible Decoder,0x00200000,1,1,NeAudible.ax,4.02.0012.0009
WMT MuxDeMux Filter,0x00200000,0,0,wmm2filt.dll,2.01.4026.0000
Avid DVBuffers,0x00200000,1,1,DVBuffers.ax,5.07.0001.1830
Nero Subpicture Decoder,0x00400000,1,1,NeSubpicture.ax,4.02.0012.0009
Full Screen Renderer,0x00200000,1,0,quartz.dll,6.05.2600.2749
Nero Scene Detector 2,0×00200000,2,0,NeSceneDetector.ax,4.02.0012.0009
Nero Stream Buffer Sink,0x00200000,0,0,NeSBE.ax,4.02.0012.0009
Nero Subtitle,0x00200000,1,1,NeSubtitle.ax,4.02.0012.0009
DV Muxer,0x00400000,0,0,qdv.dll,6.05.2600.2180
Nero Digital Audio Decoder,0x00400000,1,1,NeAudio.ax,4.02.0012.0009
Color Space Converter,0x00400001,1,1,quartz.dll,6.05.2600.2749
WM ASF Reader,0x00400000,0,0,qasf.dll,10.00.0000.3646
Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,10.00.0000.3646
AVI Splitter,0x00600000,1,1,quartz.dll,6.05.2600.2749
WMT AudioAnalyzer,0x00200000,1,1,wmm2filt.dll,2.01.4026.0000
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.05.2600.2749
Indeo
