Activity › Forums › Adobe After Effects › Simple volumes, box, cylinder, pyramid, New CINEMA 4D renderer, render outlines
  • Simple volumes, box, cylinder, pyramid, New CINEMA 4D renderer, render outlines
    Posted by Joel Arvidsson on November 17, 2016 at 10:41 am
    I need to illustrate volumes of simple geometry shapes such as boxes, cylinders, pyramid. I only need to describe the shapes with lines for visible outlines of the objects and dotted lines where you se throw the object (classic style).
    But now with the cinema 4d integration with in after effect I was thinking maby there is a more nice way to present simple volumes with real 3d objects instead of illustratior images. Is there a way to extrude a square to a box and have after effect to show only the outlines? The best would be to have the obscured edges dotted to make everything more clear. If its possible it would be nice since you could rotatet and tilt the objects within after effect if needed.
    joelarvidsson@gmail.com
    Michael Szalapski replied 9 years, 10 months ago 3 Members · 3 Replies
