Activity Forums Adobe Premiere Pro Simple Transitions in CS5 – a Problem
  • Simple Transitions in CS5 – a Problem
    Posted by Johannes Schwarz on October 29, 2010 at 6:21 pm
    Hi there,
    I’m stupefied by a problem in CS5 I’m struggeling with
    some clips which I cannot join by a “dip to black” or any other transition (not even a simple crossover). The transition is simply ignored.
    What I’ve tried:
    1) The two clips were admittedly large stills (2000pix * 1800 pix). As there are known issues with the stills handling I exported them into a mov and wanted to join them with the transition. I also exported as DV. Both times no luck in joining the resulting files with a transition. transition does not play
    2) I restarted the program: no luck
    3) I rebooted: no luck
    4) I can place a working transition at other places in the timeline.
    I’m at a loss
    Greetings Johannes
    Brian Barkley replied 15 years, 10 months ago 3 Members · 2 Replies
  • Alex Udell
    October 29, 2010 at 6:48 pm
    Is this to say….you can apply the transition on the sequence, but it has no effect?
  • Brian Barkley
    October 29, 2010 at 10:11 pm
    Why are they mov files? Why don’t you make them JPEGs and see if that works.
