Activity Forums Adobe InDesign Simple Table Border Question
  • Simple Table Border Question
    Posted by Matt Lawrence on August 23, 2012 at 1:51 pm
    I’m having problems getting consistent table cell borders using the default table settings (or any other for that matter). When I create a table with a 1pt solid border and 1pt solid cell borders on all sides (the default setting), the column borders are not consistent. Some of them appear doubled, or slightly thicker than others. And it’s not an alternating pattern (all alternating row and column settings are off).
    I just want a simple table with all lines at exactly 1pt.
    Any ideas as to what I’m doing wrong?
    InDesign CS6 Mac
    Matt Lawrence replied 14 years ago 2 Members · 2 Replies
  • Dwayne Smith
    August 25, 2012 at 10:59 am
    G’day Matt
    That’s a weird one. You don’t somehow have cells within cells do you?
    (although I expect you’d see these as distinct frames)
    Try selecting the entire table and using your control panel to set all the borders to 0pt.
    Do you still see any keylines?
    If not then set them all to 1pt and see if things look better.
    d.
  • Matt Lawrence
    August 25, 2012 at 9:56 pm
    No cells within cells. I get it when I create a new table using the default settings in a blank document with no styles other than the default. It’s bizarre. Making all borders 2 points seems to help sometimes, though not always. Also, it’s not consistent from table to table, meaning which particular cell borders have this extra thickness. Weird.
