Activity Forums Apple Final Cut Pro Legacy Simple System Preferences Question
  • Simple System Preferences Question
    Posted by Quinn Costello on January 27, 2007 at 1:18 am
    Simple question but I can’t figure out the answer: I’m working with multiple projects but every time I open up a new project it defaults to saving media to the last project’s scratch disk folder. Any idea how to set it up so I don’t need to tell it to save to it’s original folder everytime? Much thanks.
    Steven Gonzales replied 19 years, 8 months ago 2 Members · 1 Reply
  • Steven Gonzales
    January 27, 2007 at 1:28 am
    I think you might be able to set up each project by logging on to the operating system as a different user (which would give them different preferences files) and then use fast user switching to login to a different ‘user space’ for each project.
    I haven’t tried this, but it should work.
    From Mac Help:
    You can turn on “fast user switching” to allow more than one user to stay logged in to a computer at a time. For example, if you’re working on a spreadsheet of financial data and your daughter begs to check for iChat AV messages, you can switch to your daughter’s account. When she’s done checking for messages, you can switch back to your account and your spreadsheet is right where you left it.
    When fast user switching is turned on, the name of the current user is displayed in the upper-right corner of the menu bar. You can click the name to select another user to switch to. If the other user’s account doesn’t require a password, the computer switches automatically to the new user’s home folder. Otherwise, you see a dialog asking for the user’s password.
