Activity Forums Adobe Premiere Pro Simple spill suppression
  • Simple spill suppression
    Posted by Ragno Man on June 14, 2007 at 2:31 pm
    I’m trying to do a simple green-screen color suppression much like After Effects has with the “Hue/Saturation” effect.
    I’ve tried to copy that plug-in in Premiere’s various plug-in folders, but to no avail – Premiere doesn’t detect it.
    Is this possible to do in Premiere with or without the “Hue/Saturation” effect?
    thank you….
    Darren Edwards replied 19 years, 3 months ago 2 Members · 3 Replies
  • Darren Edwards
    June 14, 2007 at 2:53 pm
    Hi Ragno,
    If it’s not possible to … simply do it in AE, then
    can you explain the effect/plugin.
    Darren.
    myspace.com/xgfmedia
  • Ragno Man
    June 14, 2007 at 3:22 pm
    Darren,
    Thanks for the reply. Unfortunately, my workflow dictates that I do it in Premiere.
    Isn’t there just a way (maybe using the color correction effect) to select a color range (in this case “greens”) and turn down its saturation?
    thanks….
  • Darren Edwards
    June 15, 2007 at 1:32 pm
    I still don’t know what the ‘hue/saturation’ effect is,
    but if want to keyframe a range of chroma-greens, that’s
    easily done. Effects/Keying/Color Key/click the little
    colour rectangle in the Color Key-Effects Control palette
    to open the Color Picker, select you initial green,
    keyframe it, move along the timeline, reclick the rectangle
    to select a different shade etc. etc. PPro will
    automatically produce a colour transition effect between
    your keyframed greens. – You’ll be able to watch it change shade
    in the Effects Control palette if you scrub along the timeline
    inside the Effects Control palette itself.
    D.
