Activity › Forums › Apple Motion › Simple Rig Question
  • Simple Rig Question
    Posted by David Mathis on October 2, 2014 at 5:56 pm
    Greetings!
    I am wanting to build my own cross dissolve transition but add some blend mode options to give it a little something extra. In the process I want to restrict the blend modes to just normal, add, lighten, screen and overlay.
    This is where I am having an issue. On the “Clip B” I click on the little triangle next to blend mode to add it to a new rig which uses the drop down menu. I then go into the rig, create as many options as I need and give them a specific name such as “normal.”
    The first option is normal and I start the rig recording (whatever it is called), select normal and stop recording. Do the same for add, lighten, screen and overlay. Easy enough. After everything is finished I publish the template. So far so good.
    When inside FCP X, I add the transition but all the blend modes are available, not just the ones I only want available. Just want the blend modes restricted as mentioned earlier. Is there a setting I am missing or is this not possible? I have tried this three times and get the same result each time. Any assistance is greatly appreciated.
    * EDIT *
    I only published the rig parameters, not the blend mode on “Clip B” in the transition template. In other words nothing was published on a group or object level, just the rig itself.
    Mark Spencer replied 11 years, 12 months ago 2 Members · 3 Replies
  • Mark Spencer
    October 2, 2014 at 9:59 pm
    You need to create a rig and use a pop-up widget with the blend modes you want added as states, and then publish with widget.
    Mark Spencer
    Freelance Producer/Editor/Motion Graphics Artist
    Apple-certified Master Trainer
    Author, Motion 4 from Peachpit Press
    https://www.applemotion.net
  • David Mathis
    October 3, 2014 at 12:10 am
    Thank you. I now have two pop-up menus. One with the blend modes I selected and another with all blend modes.
  • Mark Spencer
    October 3, 2014 at 12:17 am
    Unpublish the one you don’t want.
    Mark Spencer
