Activity Forums Adobe After Effects Simple Render suddenly takes hours to render?!
  • Simple Render suddenly takes hours to render?!
    Posted by Richard Garabedain on June 23, 2015 at 9:20 pm
    I have a 2011 IMAC Pro. I have always had pretty good render times. It has been a month or two since i opened up after effects at home, but a simple particle world fire animation with a 150×150 texture size is taking me 3 hours to render. sure it is a 3 minute video, but it looks like a 30 minute render tops. Any tips?….besides getting another computer!
    Walter Soyka replied 11 years, 2 months ago 4 Members · 7 Replies
  • 7 Replies
  • Derek Boettcher
    June 23, 2015 at 9:25 pm
    try cleaning out your disk / memory caches and export it to a separate Hard Drive than the one the file is saved too. Sometimes that works for me.
    If you have an SSD in there, try saving it to that.
    Best,
    Derek Boettcher
    Creative Management
    BTH Media Group
    https://bthmedia.com
  • Claude Rozsa
    June 24, 2015 at 5:25 am
    Hi Derek, Should the Conformed Media caches on the same Hard drive?
    thanks
    Claude
  • Walter Soyka
    June 24, 2015 at 10:17 am
    What are your system specs and multiprocessing settings? Are you accidentally working in a Ray-traced 3D comp instead of a Classic 3D comp?
    Walter Soyka
    @keenlive   |   RenderBreak [blog]   |   Profile [LinkedIn]
  • Claude Rozsa
    June 24, 2015 at 11:24 am
    Hi Walter, don’t know if your question is addressed to me or to Richard but as I have sometimes the same problem your advice would be welcome. I’ve already changed the location of cache file and nothing else. Here are the infos you ask for:
    System
    Video Card and Disk and drivers
    Media disk cache settings in AE CC2014 latest update
    Memory and multiprocessing settings
    I haven’t tested yet the change of the effect of the cache location. But yesterday I had a rather heavy project to render and it took 6 hours! Even for a retired banker this is a bit long !!!!LOL!
    You can watch the vidéo here: https://vimeo.com/128352749
    Thanks in advance for your recommendations
    Claude
  • Walter Soyka
    June 24, 2015 at 12:05 pm
    Maybe try reserving a little more RAM for other applications.
    Walter Soyka
  • Richard Garabedain
    June 24, 2015 at 1:33 pm
    I took out some parts, cleared my ae memory and my render times were much better thanks. I don’t know how i forgot to clear the memory.
  • Walter Soyka
    June 24, 2015 at 1:48 pm
    [Richard Garabedain] “I took out some parts, cleared my ae memory and my render times were much better thanks. I don’t know how i forgot to clear the memory.”
    You should not have to manually purge memory before starting a render. In fact, if you’re previewing at the same resolution as you are rendering, NOT clearing memory should speed up your final renders as Ae will hold final frames in its green-line RAM cache.
    Walter Soyka
