Activity › Forums › Boris FX Particle Illusion › Simple question from Newbie
  • Simple question from Newbie
    Posted by Opusguy on June 12, 2006 at 11:52 pm
    Am using the SE version, and don’t know how to ” regulate ” the length of time that an emitter ” does it’s thing “. In other words, I just want the thing to come on, do it’s thing for say, 5 secs, and then ” vanish ” into a black screen.Hope someone can help me.
    Thank you very much
    Opusguy replied 20 years, 3 months ago 2 Members · 2 Replies
  • Elvis Deane
    June 13, 2006 at 3:06 am
    There are a few ways to do this. First, you can animate the Number graph and set a keyframe with a value of 0 at the frame you want the particles to stop emitting. That will kill any new particles from being born.
    You can also just fade the particles out by setting a key with a 0 value on the Visibility graph. Particles will still be created, but they’ll be invisible.
    If you just want to turn the emitter off entirely, you can set a key on the Active graph which acts like an On/Off switch. All the particles from that emitter will vanish at that point.
    Elvis Deane!
    The Apprentice Magician’s Guide to particleIllusion
    The particleIllusion FAQ
  • Opusguy
    June 13, 2006 at 4:05 am
    Thanks Elvis-I will give it a go.
