Activity › Forums › Adobe After Effects › simple question: belief how to make a crowd (I dont get it…)
  • simple question: belief how to make a crowd (I dont get it…)
    Posted by Cicit on September 12, 2006 at 2:50 am
    Hi pppls,
    I watched the belief tutorial how to make a crowd:
    https://www.apple.com/pro/video/belief/video3.html
    I am a newbee so
    The parts I dont get it are:
    1. how belief remove Bad Key area with a layer? what is crush layer? exactly? why not using keying effect?
    2. how to make gradation with a layer? is it displacement layer?
    3. Can we use quicktime movie transparant? like the disco ball with rays that belief use, I saw in the timeline it is a quictime movie, how to produce the transparant in quicktime movie? render it with alpha?
    Thats all my question, for now I think I dont have problems with the crowds 🙂 just those..
    any answers I will Appreciate it.
    Cicit
    Reloaded replied 20 years ago 6 Members · 11 Replies
  • 11 Replies
  • Jeff Memmer
    September 12, 2006 at 4:20 am
    It sounds like you need to also view this video from them, titled “Behind the Green Screen,” where they briefly tell you all the plug-ins they use, and how they managed to build the composite with a very tight budget over a 2 month period…
    https://www.apple.com/pro/video/belief/video2.html
    Good Luck
  • Cicit
    September 12, 2006 at 4:50 am
    Hi jeff
    I aprreciate your post
    but I did watch that video, and I know they use particular
    and when you read carefully, I ask technical question regarding one of may steps in the
    how to make a crowd video, which I missed and I dont get it until now how to do that step
    1. how to crash color to remove bad key, etc?
    2. regarding gradient at the legs
    3. regarding the transparancy in quicktime
    anyone?
    thanks
    Citra
  • John Cuevas
    September 12, 2006 at 1:40 pm
    Crushing the blacks refers to making the blacks, SUPERBLACK.
    Take some video footage and apply a levels effect to it. Take the video imput slider for black and move it to say 50. That would be crushing the blacks. If you look you can adjust both the RGB or Alpha channel. They adjusted the alpha channel, and made the blacks superblack. This affects the video levels, but gives them a cleaner key. You can see when they crush the blacks, how the video level comes down, in the video.
    The gradiet fill is achieved by creating a ramp. Create a solid, add the ramp effect, then lay it over your video. You can use the siloutte luma transfer mode, or the luma track mode of the video layer. Will give that soft edge.
    Afterwards, they rendered it out with a alpha channel.
    The elements have alpha’s, that how transparents are created.
    Johnny Cuevas, Editor
    http://www.ckandco.net
  • Cicit
    September 12, 2006 at 1:59 pm
    Hi Thanks John
    oh thats level effect
    why they use a layer? is that a displacement layer?
    I wonder why not using the effect to that specific crowd movie? oh is that because they have 2 layers ? so its easier to get displacement?
    thanks again
    Citra
  • John Cuevas
    September 12, 2006 at 2:19 pm
    I believe they used an adjustment layer, then a layer for the ramp. The adjustment layer effects everything below it. So I think you are right, they put the levels effect on there, since they were looping the video, this way they only had to do the effect once, rather then twice.
  • Reloaded
    September 12, 2006 at 7:00 pm
    Well, if you are in doubt about how to use the ramp to create that opacity gradient, just create a big mask and feather its edge. You ‘ll have the same result. About the Quicktime transparency, other people have already answered it, but another way you can achieve this effect, is not to render the comp, just drag it to the next comp and it will be automaticly transparent (but it can increase render time).
    Maybe these tips sound dumb for many advanced users, but remember something very important. No matter the way you do it, if the final result is what you need, it’s OK. There are different ways to achieve the same effect.
    I hope it helps.
  • Cicit
    September 13, 2006 at 3:23 am
    Hi Reloaded
    thanks for the tips
    So I assume if we in a big projects, rander each of the composition first would decrease the final rander time later?
    I totally agree with you the final result that matters 🙂
    thanks
  • Serge Hamad
    September 13, 2006 at 4:20 am
    [cicit] “So I assume if we in a big projects, rander each of the composition first would decrease the final rander time later?”
    Yes. But! If you are really dealing with a big project I would also advise you to work with proxies as much as you can as pre-rendering 20 or more comps can lead you to a mess especially when the client or even yourself want to alter things, like timing etc…
    Salut.
    Serge
  • Cicit
    September 13, 2006 at 5:03 am
    Hi Serge
    thanks for the addition
    you mean proxy like network randering? do you know any tutorial or resource how can I do that?
    it will means a lot to me
    thanks in advnce
    Citra
  • Kitfxxx
    September 13, 2006 at 9:59 am
    hi john n cicit,
    I will have the job that have to creating crowd.about next 2 weeks, so i need ur help guys..i still dont get it how it works…i mean if i have the setup that u done or u can give me and teach me step by step with the picture/files…coz i am still learning AE..new comer. SO basically..i have to create crowd in concert halll..that’s all.
    regards,
