Activity Forums Maxon Cinema 4D simple ques – preview range
  • simple ques – preview range
    Posted by Espinoza on September 21, 2006 at 9:54 pm
    i cant find any tips in the manual for using/setting the preview range. i am used to the ae way of setting a work area. the play head will just play past the green preview range i set up, (so far i only know how to set the preview range by dragging)
    thanks
    Adam Trachtenberg replied 20 years ago 3 Members · 2 Replies
  • Mylenium
    September 22, 2006 at 6:16 am
    You can’t do that in C4D other than by adjusting the overall scene length. When you create a preview from the Render menu however, you can adjust the start and end frame.
    Mylenium
    [Pour Myl
  • Adam Trachtenberg
    September 23, 2006 at 2:02 am
    I’m not sure I understand the question, but you can restrict playback to the preview range by selecting Animation>Play Mode>Preview Range.
