Activity Forums Apple Final Cut Pro Legacy simple problem: activate audio tracks in sequence
  • simple problem: activate audio tracks in sequence
    Posted by Jack Nastowski on October 2, 2006 at 9:00 pm
    I would think this would be really simple to do. It probably is, but I can’t figure it out. How do you activate audio tracks in the sequence so that you can do inserts.
    Basically:
    I open up my project and I can only get audio track a1 to connect to A1 or A2. How do I get a2 to show up?
    Sometimes it is there, sometimes it isn’t.
    Martin Baker replied 19 years, 11 months ago 3 Members · 2 Replies
  • Shane Ross
    October 2, 2006 at 9:31 pm
    It is only there if you have two tracks of audio in your SOURCE CLIP. If you open a clip in the Viewer, and you only see A1, then you only have one track of audio. Look at the viewer tabs too. You will only see one track of audio. If you open a clip in the viewer and you see A1 and A2, then you have two tracks of audio.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • Martin Baker
    October 2, 2006 at 10:05 pm
    There is a situation where source audio tracks can get lost – if you’ve had it patched to a track which has since been deleted.
    Either way, right-click on one of the track locks and choose “Reset Panel”. That will reset v1 to V1, a1 to A1 and a2 to A2.
    Martin
    Digital Heaven, London UK
    Unique plug-ins and tools for Apple Pro Apps
    NEW! DH_RetroTV and DH_Dream plug-ins for FCP
    NEW! Hot Tips video podcast for FCP
