Activity › Forums › Zaxwerks › Simple primatives and duplicates – why are they tied together
  • Simple primatives and duplicates – why are they tied together
    Posted by Ken Latman on September 29, 2009 at 4:14 pm
    I created a cube in proanimator and duplicated the object track three times. I want to have three cubes that the size, bevels, transparencies, but not color. Why is it when I try and change the color of one all fo them change? How do I break this link?
    Ken Latman replied 16 years, 12 months ago 2 Members · 2 Replies
  • Edward Wu
    September 29, 2009 at 4:27 pm
    Hi Ken,
    It sounds like you are using a Linked Object Style on the cubes that you’ve created.
    To break the link, select your object, and go to the “Object Styles” tab. Select the “Swatch” drop down menu, and select the “Unlink Object Style” command. You should now be able to customize the object color without affecting the other objects.
    Best,
    Edward
  • Ken Latman
    September 29, 2009 at 4:40 pm
    Thanks again Edward. That solved my problem.
