Activity Forums Adobe After Effects Expressions Simple “pixel style” mouth animation
  • Simple “pixel style” mouth animation
    Posted by Magnus Hellmen on January 6, 2017 at 1:32 pm
    Hello, first post here, I’m trying to transition to AE from Moho because I find Moho too buggy and inconsistent.
    I do pixel-art style animation where a character’s mouth is just alternating rectangle shapes with different colours. One for mouth open, one for closed. My goal is to animate this automatically using the .wav dialogue file. In Moho I had a switch layer where I would manually select the mouth based on the audio, which is tedious.
    I’ve been trying to experiment with a two-valued slider that would be at either 0 (mouth closed shape) or 1 (mouth open) depending on the amplitude of the audio waveform but I can’t get it to work.
    But then I thought maybe there’s an easier way to do this. Like have a square shape in AE that changes opacity based on the amplitude.
    I’m coming at this from a life of no scripting so I’m struggling to think more like a programmer.
    Any suggestions on how to solve this, I’m sure, simple problem would be much appreciated.
    Magnus Hellmen replied 9 years, 7 months ago 2 Members · 2 Replies
  • Jerry D’arts
    January 8, 2017 at 12:35 am
    Hi Magnus, snap this is my first post too.
    But hopefully this will help, and its a script called AutoLypSync I tried it today since I needed to do he same thing.
    It’s pretty straight forward and basically steps you through the process, have to say it does a pretty good job.
    I downloaded a trial from aescripts.com and costs about $40
  • Magnus Hellmen
    January 8, 2017 at 1:51 pm
    Great, thanks. For now I’ve solved it simply by connecting the open_mouth image opacity value to the keyframe slider created from the audio waveform. That way it blinks in sync with the dialogue which look pixel-tacky enough for my purposes.
