Activity Forums Adobe After Effects simple pixel aspect ratio question
  • simple pixel aspect ratio question
    Posted by Sean Bowerman on July 27, 2006 at 6:59 pm
    ok, i know this has probably been addressed 100’s of times already but apologies, i can’t see my answer…
    i’ve got a comp set up in AE as NTSC widescreen 720×480 Pixel Aspect Ratio D1/DV NTSC Widescreen. I need to render it out for widescreen dvd. I render it using the Animation codec. Set up a widescreen project in iDVD. Burn a dvd and it comes out….. squashed. 4:3.
    Have i set it up right? when i use the Toggle Pixel Aspect Ratio Correction it looks perfect. Is this a problem with iDVD?
    any answers/suggestions would be greatfully recieved before i go hang myself with a digital rope.
    thanks in advance.
    Mylenium replied 20 years, 1 month ago 3 Members · 4 Replies
  • Steve Roberts
    July 27, 2006 at 7:27 pm
    In DVD Studio Pro you set a flag for 16:9 or widescreen. Maybe iDVD has the same thing.
  • Sean Bowerman
    July 27, 2006 at 7:30 pm
    yeah i did that.
    i do have dvd studio pro 2, but no idea how to set it up. is it complicated?
  • Steve Roberts
    July 27, 2006 at 8:38 pm
    We now officially belong in another forum. 🙂
  • Mylenium
    July 28, 2006 at 5:55 am
    Make sure your DVD-player is setup properly. Many models don’t auto-switch between different ratios properly, you have to manually configure them.
    Mylenium
    [Pour Myl
