Activity Forums Boris FX Particle Illusion Simple particle effects
  • Simple particle effects
    Posted by Jeremy Reed on September 5, 2011 at 6:16 am
    What is the simplest particle effect that I can create with After Effects? I am very new but I would like to learn to do this.
    Thank you
    Jeremy Reed replied 15 years ago 2 Members · 2 Replies
  • Alan Lorence
    September 6, 2011 at 1:45 pm
    You mean with After Effects alone, or with particleIllusion in After Effects?
    With particleIllusion, load the “blank” emitter library. It contains a “default” emitter. Also, the second emitter in the “Default” library is called “Simple Sparkles” — it’s pretty basic.
    If you’re talking about After Effects alone and not particleIllusion, you posted in the wrong forum.
    Alan.
    http://www.wondertouch.com
  • Jeremy Reed
    September 6, 2011 at 8:53 pm
    Oh! I posted in the wrong forum. You see, I have an assignment in my After Effect class to post here. The point of the assignment is to familiarize myself with the CreativeCow forum. Thank you. Next time I will look more carefully at the categories listed.
