Activity Forums Adobe After Effects Simple Paint question.
  • Simple Paint question.
    Posted by Burns S on April 24, 2006 at 4:19 pm
    This is pretty simple, i just dont know it. I am going thru an after effects book ( after effects hot 6.0) I have after effects 7. Most of the lessons have been super easy to follow along, just because the lay out has been pretty much the same. I am on the paint chapter. Basically your spose to paint something ( did it) it disappears and then you click on the write on tab. This tab is not in the same place in 6.0 as it was in 7.0. I have no clue where it is. If someone could tell me where this tab is so you can get the paint to appear that would be great.
    Burns
    Burns S replied 20 years, 4 months ago 2 Members · 2 Replies
  • Tim Kurkoski
    April 25, 2006 at 6:03 pm
    The Write On option is in the same place in AE 6.0 and 7.0- in the Duration drop-down menu in the Paint palette.
    There is also an effect (not a part of the Paint engine) called Write-on, and it’s location changed between versions. In AE 6.0 it is listed under the Stylize category. In AE 7.0 it is under the Generate category.
  • Burns S
    April 25, 2006 at 8:51 pm
    hey,
    thanks that helped alot
