Activity › Forums › Maxon Cinema 4D › Simple outline with depth using Sketch and Toon
  • Simple outline with depth using Sketch and Toon
    Posted by Brian Murphy on August 25, 2014 at 4:17 am
    After modifying the values and checking boxes til I can’t take it any more…
    I just want to use a Sektch and Toon material to outline all objects in the scene but I also need to have lines on the inside of the mesh to show thickness. I don’t want to see any lines indicating where polygons or vertexes are…just a simple tech rendering.
    Imagine several flat cubes positioned near one another, several are rotated, some have a bevel. I need to see the borders of these objects along with a line on the inside to show their thickness…nothing else. Is there a simple setup for this that will work at all angles if I move a camera around them?
    Thanks all,
    Brian
    Adam Trachtenberg replied 12 years, 1 month ago 2 Members · 5 Replies
  • Adam Trachtenberg
    August 25, 2014 at 1:22 pm
    Not sure what you mean by, “lines on the inside of the mesh to show thickness.” Can you post a sketch to show what you’re looking for?
  • Brian Murphy
    August 25, 2014 at 2:07 pm
    Thanks Adam, here’s a render of how far I’ve gotten. Those little anomalies and undesirable lines drive me nuts. These are simply flat shapes carved from cubes. I just want to show the outside of them and the thickness line on the inside (green).
    Brian
  • Adam Trachtenberg
    August 25, 2014 at 3:12 pm
    Okay, I think you’ll get what you want if you set the Lines to just use Creases and Angle, and then set the angle to something like 33 Min and 95 Max.
  • Brian Murphy
    August 26, 2014 at 2:34 pm
    Thanks Adam!
    That got me about 90% there. Sketch is a tricky bird…can’t seem to get those poly lines angling in from the rounded corners. There are some squares showing up on a beveled edge too. Tried adjusting the angles but I either lost some important outlines or gained too many lines in the edges of the flattened cubes.
  • Adam Trachtenberg
    August 26, 2014 at 5:00 pm
    If the geometry is editable it may just be time to resort to edge selections….
