Activity Forums Adobe After Effects simple opacity expression
  • simple opacity expression
    Posted by Bryanisfishing on April 24, 2006 at 9:24 pm
    i’m looking for an expression where I change the opacity of an object from 0-100 over a set amount of time..
    for example
    from 0-10 seconds.. i want “x” amount of keyframes to make an object appear and disappear… rather than creating keyframes..
    basically making an object blink..
    Matthias Gottung replied 20 years, 4 months ago 2 Members · 1 Reply
  • Matthias Gottung
    April 27, 2006 at 7:44 am
    Hey bryanisfishing
    I played around with the sinus funktion and I found this little line to help you with your problem
    Math.sin((time*0.31415915) *5 )*1000000;
    The sinus funktion makes the value of the opacity go up and down
    the variable time is the timeline variable that feeds the sinus funktion with a continous value
    the strange number 0.31415915 is actually there to calibrate the blinking to almost exactly 10seconds. (correct for more than 1hour)
    the *5 is the “x” value that you would want to change to set the blinking to your needs
    it goes like this
    10seconds / x = blinking time
    so here it would be 10/5 = 2 so every 2 seconds the layer changes the opacity from 0 to 100
    the *1000000 is used so that the blinking isn’t fading.
    I hope I could help you
