Activity Forums Adobe After Effects Expressions Simple Opacity Expression ?help?
  • Simple Opacity Expression ?help?
    Posted by Robin Hamilton on August 15, 2007 at 3:58 pm
    I tried searching for this, but can’t quite figure out what to call it 🙂
    Basically I want the opacity of one layer to be linked with the opacity of another layer, but in a negative way. I am using hold keyframes to turn a layer’s opacity from 0% to 100%. I would like another layer to do the opposite… So all I have to do throughout the animation is set hold keyframes for one layer, and the other layer’s opacity will go to 100% when the keyframed layer is set to 0%.
    I know this should be a simple expression, but it seems the programming side of my brain doesn’t work too well.
    Mark Likosky replied 14 years, 6 months ago 5 Members · 11 Replies
  • 11 Replies
  • Lord Scales
    August 15, 2007 at 4:54 pm
    Try this:
    layerOp = thisComp.layer (“Layer 1”).opacity //the other layer
    linear (layerOp, 0, 100, 100, 0) //as the opacity goes from 0 to 100, the value goes from 100 to 0
  • Robin Hamilton
    August 15, 2007 at 4:58 pm
    That works perfectly. I was waaaaay off on the wrong path. I would never have figured that out.
    Thanks a lot.
  • Dan Ebberts
    August 15, 2007 at 5:00 pm
    This is a little simpler:
    100 – thisComp.layer(“Layer 1”).transform.opacity
    Dan
  • Robin Hamilton
    August 15, 2007 at 7:21 pm
    Thanks Dan, that works great as well.
  • Gary Mayes
    March 14, 2010 at 12:11 pm
    Hi guys
    I’m not a natural when it comes to expressions, so hence me asking this – Why oh why does the 100 – at the front of ‘100 – thisComp.layer(“Layer 1”).transform.opacity’ make this happen? Finding this was so helpful, as it meant that I didn’t need to keyframe two layers to replace one element with another.
    I just want to understand what’s going on in such a simple expression. Help me learn – please!
    Gary
    Motion graphics designer and filmmaker
  • Dan Ebberts
    March 14, 2010 at 11:00 pm
    When Layer 1’s opacity is 100, this layer’s (the layer with the expression) opacity is 100 – 100, which is zero. When Layer 1’s opacity is 50, this layer’s opacity is 100 – 50, which is 50. So the “100 – ” is what establishes the inverse relationship between the opacities of the two layers.
    Dan
  • Gary Mayes
    March 15, 2010 at 9:57 am
    Thanks Dan, that makes perfect sense!
    Gary
  • Mark Likosky
    March 16, 2012 at 7:25 pm
    I’m trying to create a preset or expression to fade out the last 7 frames. Having a hard time figuring out to make it happen.
    thought this was a similar thread on how to do that
  • Dan Ebberts
    March 16, 2012 at 7:34 pm
    Try this:
    fadeDur = framesToTime(7);
    ease(time,outPoint-fadeDur,outPoint,value,0)
    Dan
  • Mark Likosky
    March 16, 2012 at 8:13 pm
    Dan,
    That seems to work nicely!
    I’m just getting the hang of expressions. How do I save that as a preset?
    Thx!
