Activity Forums Storage & Archiving Simple network
  • Simple network
    Posted by John Kaley on July 30, 2013 at 2:46 pm
    I’m looking to build a simple 2 user shared storage network for an upcoming project. The footage is 1920×1080 ProRes 422 @ 100mbits/sec.
    The “server” computer is a 64bit 2009 MacPro 8 core with 16mb ram. This has an 8TB Caldigit raid 5 connected via mini SAS.
    The other computer is a current iMac 27″ with 32mb ram.
    For a “stock” gigabit network, can I simply connect an ethernet crossover cable between the MacPro’s second ethernet port and the iMac with jumbo frames enabled? I realize I will get less streams per user.
    If I want to move up to a 10GbE network, can I simple install a Small Tree 10GbE PCI card into the MacPro and a ThunderNet box for the iMac with a Cat6 crossover cable?
    Any insight would be very helpful. Thanks!
    Alex Gerulaitis replied 13 years, 1 month ago 4 Members · 4 Replies
  • Ericbowen
    July 30, 2013 at 3:29 pm
    Yes you can do both although the 10Gbit network adapters should autosense on the ports and you should not require crossover cables.
    Eric-ADK
    Tech Manager
  • Eric Hansen
    July 30, 2013 at 3:35 pm
    no crossover cable needed on the internal ports either
    e
    Eric Hansen
    Production Workflow Designer / Consultant / Colorist / DIT
    https://www.erichansen.tv
  • John Kaley
    July 30, 2013 at 5:09 pm
    Thanks for the replies. I tested the gigabit speed and I’m getting 106 MB/sec. using the AJA System Test. What kind of speed can expect from the 10GbE Small Tree solution? 300-400 MB/sec?
  • Alex Gerulaitis
    July 30, 2013 at 5:30 pm
    [John Kaley] “What kind of speed can expect from the 10GbE Small Tree solution? 300-400 MB/sec?”
    Here are some tests from the field:
    350MB/s writes, 250MB/s reads – 2008 xServe, 16-drive RAID6 DAS, OSX 10.6 server, Small-Tree 10GbE PCIe in the xServe, Thunderbolt 10GbE NICs in Magma chassis on the clients.
    620MB/s writes yet still 250MB/s reads – same as above except in OSX 10.7 server which allows to use a later version of the Small-Tree driver. The relatively slow reads are likely an indication of xServe limitations. We’ll know more once the client tests a Mac Pro in a similar configuration.
    Also tested were ATTO PCIe and Thunderbolt 10GbE NICs: similar speeds with a switch; direct cabling (no switch) however locked the cards into a 1GbE link limiting speeds to 110MB/s. Strangely, ATTO drivers didn’t allow to force a 10GbE link. Also, their TB chassis (Sonnet I believe) is also much louder than the Magma one, which didn’t work for a client. ATTO support however is top notch, and they’re looking into these issues which they hope will be fixed soon.
    Alex Gerulaitis
    Systems Engineer
    DV411 – Los Angeles, CA
