Activity › Forums › Adobe After Effects Expressions › simple move expression
  • simple move expression
    Posted by Simon Bisset on February 28, 2014 at 11:58 am
    Hi everyone. First time here, so hope you can help!
    I am using a ‘Hole’ effect and have pick-whipped from the effects Centre to the position data on a Mocha Move NULL object (some tracking data).
    So far so good, and I have the expresion:
    thisComp.layer(“Mocha Move NULL”).transform.position
    This works fine, but I now want to fine tune the x,y data more accurately to place the Hole centre where I like. So my question is, what additional text do I need to add to the expression above to do this?
    Many Thanks,
    Simon
    thisComp.layer("Mocha Move NULL").transform.position
    http://www.focal-point.co.uk
    Simon Bisset replied 12 years, 7 months ago 2 Members · 2 Replies
  • Dan Ebberts
    February 28, 2014 at 3:49 pm
    Do you mean you want to add a static offset? That could be done like this:
    xOffset = 50;
    yOffset = -25;
    thisComp.layer(“Mocha Move NULL”).transform.position + [xOffset,yOffset]
    You could tie xOffset and yOffset to sliders if you want to be able to adjust manually (or keyframe the adjustment amounts).
    Dan
  • Simon Bisset
    February 28, 2014 at 4:35 pm
    Hi Dan, That’s perfect!
    Thanks very much.
    Regards, Simon
    ps, check out my film to see what i’m up to 😉
    https://www.criteriaone.co.uk
