Activity Forums Adobe After Effects Simple Minority Report effect
  • Simple Minority Report effect
    Posted by Alex Townley on May 19, 2011 at 10:40 am
    Hi guys,
    Was wondering if I could have a little guidance on the best way to pull off this effect: https://www.youtube.com/watch?v=KmFhxKu8hKg&feature=related
    It generally looks quite easy to do but wanted to check whether it would be something I need to motion track or can I pull it off simply keyframing the position and scale etc? Would there be any special measures I should take when filming to achieve this effect?
    Cheers,
    Alex
    Tudor “ted” jelescu replied 15 years, 3 months ago 2 Members · 1 Reply
  • Tudor “ted” jelescu
    May 19, 2011 at 11:32 am
    Design an interface and work with your actor to help him/her visualize where the items will be on the virtual screen.
    It would help if you can add some light interaction: when you plan to have the screen come up have a light fade up from somewhere low – this way you can get the actors face lit up just a bit. A colored filter should help (cyan/blue). If you can make the light flicker a bit it will be even better.
    No need for tracking at this stage if you plan a static shot.
    Of course if you want camera moves you will need 3d tracking software and to work in AE in 3d space.
    Here’s a project I did a while ago:
    https://www.youtube.com/watch?v=4WcSPl76Vdg
    Tudor “Ted” Jelescu
    Senior VFX Artist
