Activity Forums Adobe After Effects Expressions Simple loop expression loop newbie
  • Simple loop expression loop newbie
    Posted by Jay Brown on February 19, 2008 at 11:44 am
    Hi
    I have a comp 4s long of a record spinning (1 revolution)
    I added the expression loopOut(“cycle”) to the rotation field
    When I nested this record pre comp in a 20sec main comp to test, the record dissappeared when the precomp record finished. (I expected the loop to repeat it to eternity so to speak)
    I have read similar posts to this but the resolution was not clearly defined
    Thanks in advance from an expression newbie
    Lloyd Alvarez replied 18 years, 6 months ago 3 Members · 2 Replies
  • Patrick Hearn
    February 21, 2008 at 12:24 pm
    As I understand it you want to apply the loopOut expression to Time Remapping on the nested comp.
  • Lloyd Alvarez
    February 26, 2008 at 5:40 am
    Set the duration of your pre-comp to an amount long enough to cover your loop. Then, when you nest the precomp, make sure the layer extends for as long as you want your loop to last.
    -Lloyd
    https://aescripts.com
