Activity Forums Adobe After Effects Simple line help needed
  • Simple line help needed
    Posted by Dan Lewis on June 15, 2006 at 1:26 pm
    I’m trying to draw a line on a map from city to another. I know how to use a mask to make it draw on but I’m having difficulty creating a line with a bezier curve to it. The line tool doesn’t seem to have that ability? Any idease? I’m using AE 6.5 and PS 6.0
    Dan
    David Bogie replied 20 years, 3 months ago 5 Members · 4 Replies
  • Kurt Murphy
    June 15, 2006 at 1:32 pm
    You can double-click the map layer and use the pen tool to create a bezier path from point A to point B. Next add the Stroke Filter to the path… I think it’s under Render in 6.5. The Stroke filter will allow you to set the color, size and softness. You can animate the line to draw on.
    Hope this helps,
    kurt murphy
  • Julian Sixx
    June 15, 2006 at 1:43 pm
  • Justin Productions
    June 15, 2006 at 2:33 pm
    Take the Pen tool, make a point “A”, then, go further in the comp window, and make a “B” Point, and just after you made your point “B”, !dont let go your left mouse button!, move your mouse to any direction and it will make a bezier curve with the line.
    Or, draw 2 points with the mask, like above, and press G four times in a row so you have the Bezier Tool. Then, just take that tool and press your “A” and/or “B” points, then move it to any directions (without letting go your mouse button, of course).
    Or check RotoBezier in the toolbox.
    Hope that helped.
    Justin Productions
    Tangerin01@hotmail.com
    Adobe After Effects 6.5 Professional
  • David Bogie
    June 15, 2006 at 9:32 pm
    Here’s another:
    Draw your line.
    Apply Cycore or Boris Sphere to the line layer.
    This will give you a trajectory up into the sky above the map.
    bogiesan
