Activity › Forums › Adobe Premiere Pro › Simple Keyboard Shortcut Question
  • Simple Keyboard Shortcut Question
    Posted by Justin Gray on October 6, 2012 at 7:13 pm
    Folks, coming from the Avid world I am use to being able to assign a single command to multiple keyboard shortcuts. For example, I like to assign the Zoom In function to both “Command +” & “Shift C.” This way no matter which side of the keyboard my hand is on at the time I can use the most convenient of the two keyboard shortcut options. Will Premiere CS6 allow me to assign single commands to multiple shortcuts? I cannot for the life of me get it this to work from within the keyboard shortcuts dialogue box.
    Thanks Fellow Bovines,
    Justin Gray
    Senior Editor/Motion Graphics Artist
    Gray Planet
    https://vimeo.com/grayplanet
    Axel Arzola replied 13 years, 11 months ago 2 Members · 3 Replies
  • Axel Arzola
    October 8, 2012 at 2:14 pm
    In the keyboard shortcuts menu you can change everything to the AVID set up. At the top of the menu, seek for a pop up menu where you can select shortcut configuration either from FCP, AVID or Premiere.
    A fast way to zoom in and out is holding ALT and using the mouse scroll, using that it really doesn’t matter where in the keyboard you are.
    Axel Arzola
    http://www.facebook.com/arzolafilm
    https://www.youtube.com/user/axelandkretel
  • Justin Gray
    October 8, 2012 at 3:31 pm
    Thank you. But that was not the question. I am trying to assign a single command to multiple keyboard shortcuts. This way I have multiple options on the keyboard for common tasks. For example I would like to have “Set In & Set Out” on multiple keyboard buttons. And “Zoom In Zoom Out” on multiple keyboard buttons. Common trim options and interface settings are tasks that I often assign to multiple keyboard button combinations.
    From what I can tell, Premiere CS6 only allows you to assign a command to one shortcut option. Pulling Avid and FCP pre-assigned layouts is not needed for me because, if you can’t tell, I have a heavily customized workflow and every non-linear I’ve ever worked with in the past allows for me do achieve this desired result of assigning a single command to multiple places on the keyboard.
    At this point I believe it is a software limitation.
    Justin Gray
    Gray Planet
  • Axel Arzola
    October 10, 2012 at 3:11 pm
    Sorry about that. Maybe next update.
    Axel Arzola
