Activity › Forums › Adobe After Effects Expressions › simple if then statement based on character length
  • simple if then statement based on character length
    Posted by Adam Greenberg on January 26, 2021 at 2:50 pm
    Hi everyone, I am sure the problem is only with the way I wrote this. I have done and modified countless expressions over the years, but this one isn’t working.
    I want my if then statement to change position by 100 pixels based on character length in a text, so here is my expression in the position property of a different layer.
    a=thisComp.layer(“text”).text.sourceText.length
    if (a>32),[960,540] else [960, 640]
    thanks so much for any help.
    To further explain the reasoning, I plan on making my text a paragraph text with a limited length horizontally, so that once the text starts appearing on the second line, the expression will move the other layer down, basically keeping this layer a certain amount of pixels lower than the text. I think there might even be better way to create this expression based on sourcerectattime for the height, but Im not sure how.
    Thank you
    Trent Armstrong replied 5 years, 8 months ago 3 Members · 6 Replies
  • Kevin Camp
    January 26, 2021 at 8:17 pm
    I would do it with using sourceRectAtTime().
    Parent the layer to the text layer and try this:
    rect = parent.sourceRectAtTime() ;
    y = rect.top + rect.height ;
    value + [ 0, y ]
  • Trent Armstrong
    January 26, 2021 at 9:14 pm
    Adam,
    I’m curious if it’s not doing what you want or if it’s breaking. I realized after much gnashing of teeth that the new expression engine asks for more coding language like:
    if (a>32) {[960,540]} else {[960, 640]}
    Kevin may have gotten you to the right place, but I wanted to make sure you’re not experiencing a “gotcha”.
    Trent
  • Adam Greenberg
    January 26, 2021 at 10:23 pm
    Trent, it was showing an error the way I wrote it. But I have no way of knowing the exact problem. your expression works perfectly. Thanks so much
  • Adam Greenberg
    January 26, 2021 at 10:24 pm
    Thanks Kevin, yes this looks amazing. I’m going to try this.
    Thanks so much
  • Adam Greenberg
    January 26, 2021 at 10:41 pm
    Kevin, what if I don’t want to parent it. I may have other things that the text layer is doing that I don’t want the null to follow. I figured out how to modify the beginning by writing the following;
    rect = thisComp.layer(“titre”).sourceRectAtTime() ;
    value + [ 0, y-160 ]
    but the problem is the null moves exponentially away from the text, as the text goes into more and more lines. I’m sure it’s an easy fix but I cant figure out the logic on this one, especially rect.top
    Thanks again for any help
  • Trent Armstrong
    January 27, 2021 at 3:11 pm
    Adam,
    That is good info. I think the problem, at least for the syntax, was the braces for the if/then statement.
    if (something) {this} else {that}
    — or —
    if (something) {
    this
    } else {
    that
    I’m not sure about your exponential movement issue, but you might need to multiply the height * .5.
    We’re all pulling for you!
