Activity Forums VEGAS Pro Simple How To Help – Please
  • Simple How To Help – Please
    Posted by Jake Zeer on February 6, 2008 at 3:39 pm
    Can someone show me How To:
    Open up a clip in the Trimmer from the “Project Media” list WITHOUT LEFT CLICKING AND CLICKING AGAIN – i.e. How do I create a shortcut to open the clip in the trimmer window with the press of a button.
    How do I grab the end of a clip on the time line that is on the BOTTOM of another clip and has a dissolve on the end. If I go to the end of the dissolve I can grab one clip to extend or shorten but sometimes I want the other clip underneath and I end up moving the 1st clip out of the way (messing up the timing) and then grab the clip I want. 🙁
    Jake Zeer replied 18 years, 7 months ago 2 Members · 2 Replies
  • Edward Troxel
    February 6, 2008 at 8:06 pm
    [Jake Zeer] “Open up a clip in the Trimmer from the “Project Media” list WITHOUT LEFT CLICKING AND CLICKING AGAIN”
    Options – Preference – and check the box for “Double Click on media file loads into Trimmer instead of tracks”
    Then double-click on them.
    [Jake Zeer] “If I go to the end of the dissolve I can grab one clip to extend or shorten but sometimes”
    You should be able to go to the end of either clip. If there’s really an overlap there, it should all work fine.
    Edward Troxel
    JETDV Scripts
  • Jake Zeer
    February 6, 2008 at 8:39 pm
    Thanks Ed – you were 100%
