Activity › Forums › Apple OS X › Simple (hopefully) Thunderbolt Question
Posted by Thomas Morter-laing on November 15, 2011 at 2:26 pmQuestion: If a Harddrive is connected to an iMac’s motherboard with sata connection, how can data be copied to or from the main hard drive faster the sata speed, even if it IS going through a thunderbolt port?
Tom Morter-Laing
Freelance Editor,
Certified Apple Product Proffessional, 2010
http://www.depictproductions.co.ukSony Z5, with Rode NTG2.
iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD.Thomas Morter-laing replied 14 years, 10 months ago 3 Members · 5 Replies -
Joel Hufford
November 15, 2011 at 4:31 pmThe quick answer Tom is that it can’t. whenever you’re considering a transfer of data between local devices on a computer, or multiple computers on a network, the speed of that transfer will be limited by the slowest connection in the chain. I suppose a “weakest link in the chain” metaphor could be used here.
SATA, depending on the flavor you’re using has a theoretical maximum speed of 1500, 3000 or 6000Mbps. Those translate into 187.5, 375 and 750 MBps. As long as you’re using a SATA interface, you will never achieve read or write speeds above those thresholds, regardless of whether or not you have a device in the transfer chain hooked up using Thunderbolt.
Of course, with that said, you’ll never achieve anything near those thresholds either, because those are theoretical maximums which disregard other factors like hard drive speed and bus communication over head etc…
I hope that helps
joel
Corporate and Special Event Staging Services
http://www.pacificstaging.com -
Thomas Morter-laing
November 15, 2011 at 4:53 pmSo in terms of speed, (nothing else), Apple may as well have just put an esata connection on the back of the iMacs right? I understand peripherals etc, but even with an 15 SSD drive RAID all its going to do is go the Sata max speed, because the internal hard drive is connected to the motherboard with Sata?
Presumably theyll update that in the future….
Tom Morter-Laing
Freelance Editor,
iMac 27″ intel i7 2.93GHz, 12GB RAM, ATI HD5750 [1GB GDDR5], 2TB Int. SATA with 2TB External HDD; (FW800), with Elgato Turbo H264HD. -
Joel Hufford
November 15, 2011 at 6:45 pmSpeaking strictly of situations where you’re interfacing with the internal SATA hard drive yes, that is where your bottleneck will be.
But Thunderbolt also has the advantage of being daisy-chainable, (I don’t think that’s word!) and, technically speaking, eSATA even in it’s newest incarnation tops out at a theoretical maximum of 6Gbps and Thunderbolt comes in at 10Gbps. Again, these aren’t actual achievable speeds, but the theoretical maximum works for comparison.
Hope that clarifies things, at least a bit!
joel
Jean-christophe Boulay
November 17, 2011 at 2:31 pmThunderbolt is supposed to be about more than just storage. You could theoretically hook up your TB storage and then daisy-chain a display into that, for instance. Then, some of the “excess” would be used for that screen. You could have two storages connected to one TB buss and getting data from two separate SATA busses, filling the pipe a bit more. The idea was basically “let’s make the pipe real big because we’ll find some way to fill it eventually”. With any data transfer right now, the storage device itself will usually be the bottleneck anyways, not its interface.
These are all just words on a screen, as Thunderbolt-equipped hardware is very thin on the ground right now. It looked awesome in the brochure, though. Time will tell how successful the interface really is, but the possibilities are there.
JC Boulay
Technical Director
Audio Z
Montreal, Canada
http://www.audioz.com -
Thomas Morter-laing
November 17, 2011 at 2:35 pmSome useful info here guys, thanks.
Incidentally I guess Thunderbolt is the thing which essentially made the iMac professional- especially in December when Sonnet are releasing a thunderbolt- express card adapter. Then all you need to do is add an express card hub and buy a whole bunch of IO adapters (not cheap) and you almost have a Mac Pro, minus some of the processing power and upgradeability…. 😀
Tom Morter-Laing
Freelance Editor,
