Activity Forums Apple Final Cut Pro Legacy Simple HDV Question
  • Bouncing Account needs new email address
    January 9, 2008 at 8:06 pm
    You can monitor the audio coming from the Deck or Camcorder’s audio jacks.
  • Mark Maness
    January 9, 2008 at 8:08 pm
    Yeah, I can…. I should have added, that’s what we are doing. The only problem seems to b a two second delay between the deck and FCP. Makes it difficult to get critical timing.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
    https://blogs.creativecow.net/waynecarey
    January 9, 2008 at 8:19 pm
    OK. This might do the trick-
    The audio is, by default, intentionally MUTED to the Mac’s speaker output during Log and Capture.
    However, there is a way you can turn ON the Mac’s speaker if you really WANT to.
    In FCP5x and later:
    In the Record Tool:
    Clip Settings, near audio buttons, choose: Preview: “ON”
  • Mark Maness
    January 9, 2008 at 8:34 pm
    I would like to do this, but HDV Log & Capture box doesn’t have this feature.
    So far, the only option that I have is to install an AJA IO LA, downconvert, and monitor thru it.
    Wayne Carey
    Schazam Productions
  • Paul Escandon
    January 9, 2008 at 9:40 pm
    You cannot monitor audio on your mac when logging HDV the way you can when capturing DV. There’s not even a check mark for it.
    Paul Escandon
    Producer | Director | Editor
    Apple Certified Trainer – Final Cut Pro
    Oremus Productions
    http://www.oremusproductions.com
    Adjunct Professor of Media
    John Paul the Great Catholic University
  • Mark Maness
    January 9, 2008 at 9:46 pm
    I’ve come to that conclusion…
    The answer is to downconvert to DV and log the footage that way. Then I can select Preview Audio to hear the audio.
    I guess I overcomplicated things with this….
    Wayne Carey
    Schazam Productions
