Activity Forums Adobe After Effects simple expressions
  • simple expressions
    Posted by Dan Brazil on August 20, 2010 at 11:33 pm
    Hello i want to animate an object from one key frame to another. But i cant because I’ve applied an expression to that property.
    I have an effect called cc sphere.
    I want to animate the y rotation.
    But i already have an expression:
    lookAt(thisComp.activeCamera.position,position)[1];
    I have done abit of research and think i need this function to animate: setValueAtTime. But I have no clue how to implement it.
    I have just completed a video copilot tutorial: https://www.videocopilot.net/tutorial/the_blue_planet_in_3d/
    Thanks daniel
    Michael Szalapski replied 16 years, 1 month ago 2 Members · 1 Reply
  • Michael Szalapski
    August 23, 2010 at 1:56 pm
    I haven’t watched that tutorial, but I’m assuming your planet texture is in a precomp, if that’s the case, you can simly use an offset effect to move the map in the precomp. It’ll then look like it’s spinning in the main comp.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
