Activity Forums Adobe After Effects Simple expression question – HELP PLEASE! :)
  • Simple expression question – HELP PLEASE! :)
    Posted by John-paul Bonadonna on September 8, 2006 at 1:25 am
    Simple expression I think….
    Ever see that Valvoline Mark Martin Ultrasound commercial? Well, imagine a still picture with an animated foot pushing a gas pedal. As the pedal is pushed, we hear revving and the picture wiggles.
    SO, how can I make the intensity of a wiggle coincide with a larger rotation value (setting up with the anchor point on the ankle).
    I’m using this as the example, but I see so many uses of this… text wiggles harder as it scales up etc…
    Any help would be so appreciated, and if you can add variables that perhaps I haven’t thought of, all the more THANKS!!!
    jpb
    John-paul Bonadonna replied 20 years ago 2 Members · 2 Replies
  • Colin Braley
    September 8, 2006 at 2:09 am
    Therees a couple different ways to get something like this done, heres the one that I would use:
    //–begin
    driver = thisComp.layer(“Rotating Layer”).transform.rotation;
    maxRot = 720;//degrees
    minRot = 0;//degrees
    freq = 3;//frequency of wiggle
    ampMin = 3;//min amplitude of wiggle
    ampMax = 30;//max amplitude of wiggle
    amp = ease(Math.abs( driver ), minRot, maxRot, ampMin, ampMax);
    wiggle(freq, amp)
    //–end
    In that expression, as rotation goes from 0 to 720 (or 0 to -720) the amplitude of the wiggle would go from 3 to 30.
    OR, you could do it like this with simpiler (but less easily adjustable code)
    div = 90;
    freq = 10;
    rot = thisComp.layer(“Rotating Layer”).transform.rotation;
    wiggle( freq, Math.abs(rot)/amp );
    in the second one just adjust div until you get something asthetically pleasing.
    Enjoy.
    ~ Colin
  • John-paul Bonadonna
    September 11, 2006 at 6:07 pm
    Pardon my delayed thanks!!!
