Activity Forums Maxon Cinema 4D simple dynamics question
  • simple dynamics question
    Posted by Chad Demoss on June 4, 2019 at 11:13 pm
    I haven’t messed around with dynamics very much but I watched a few tutorials and most of what I wanted to do was pretty easy. What I wanted was to have a sphere hit some text vertically, the text flys up, gravity pulls it back down and then it slides down a spline that I have extruded. Every thing is working except the sliding down the spline. the objects aren’t sliding down the spline if it is a wavy shape. If it’s just an arch it works or if i get rid of that and just put a sphere there it works. Ive attached the file to show what i’m trying to do.
    13407_collider.c4d.zip
    Chad Demoss replied 7 years, 3 months ago 2 Members · 2 Replies
  • Brian Jones
    June 4, 2019 at 11:48 pm
    The Dynamics Body tag on the Extrude needs to have Collision/Shape set to Static Mesh (or Automatic (MoDynamics)) – when it’s the default ‘Automatic’ it uses the bounding box of the object – which is a cuboid which surrounds the object – static mesh uses the object faces that are there, it’s slower to calculate but it will give you what you want.
  • Chad Demoss
    June 4, 2019 at 11:52 pm
    well that worked. thanks for the help.
