Activity Forums Adobe Encore DVD Simple DVD burn question
  • Simple DVD burn question
    Posted by Rick Barnett on October 10, 2010 at 6:36 pm
    Hard to believe I am having such trouble. I have a bunch of wmv files I want to simply put to dvd disks for viewing on a stand alone burner on tv. I tried winAVI but the video would freeze every time at two seconds. It played fine on the pc except there was no sound. So Encore I am trying out. I converted the wmv file with Adobe Encoder to mpeg2-dvd. I am stuck now on getting it to the Sony DVD-RW drive. In Encore cs5, in the build tab I can not choose that file. Or am I going about this the wrong way? I do want the best possible quality. Thanks in advance for any response. Rick
    Windows 7 64bit pro
    Minu Sharma replied 15 years, 11 months ago 3 Members · 5 Replies
  • Daniel Ludwig
    October 11, 2010 at 11:42 am
    rick,
    you need to learn the basics first. you can´t burn a MPEG2-file on a DVD to play it back on standalone-players.
    DVDs needs to be authored/programmed with DVD-authoring-applications like adobe Encore or apple DVD Studio Pro.
    to author DVDs you need elementary video- and audio-streams and within the authoring-app you´re creating the logical connetions between all asset – menus, videos, audio and subtitles.
    the final progress would be to mulitplex all these assets into a DVD(-folder) and to burn it to your DVD+/-R or to give it to replication-facility.
    cheers
    danny
  • Rick Barnett
    October 11, 2010 at 6:49 pm
    Yikes! These are the basics huh? Is there a tutorial I can view on this? Or step by step instructions? I don’t want to do any adjustments to these .wav files, just want to transfer them to a DVD for TV viewing. Oh and the sound to work. 🙂 Rick
  • Daniel Ludwig
    October 13, 2010 at 6:47 am
    hi rick,
    I´m creating some tutorials for blustreak at the moment, maybe I should put this on my todo-list as well.
    soon you´ll find them here: https://www.blustreak.dvdafteredit.com/
    cheers
    danny
  • Rick Barnett
    October 13, 2010 at 5:06 pm
    That would be great Dan…..much appreciated!!!
  • Minu Sharma
    October 18, 2010 at 7:00 am
    Hi Rick ,
    You have mentioned : “In Encore CS5, in the build tab I can not choose that file” what does this mean?
    Simple steps to burn your files in DVD are :
    1. Import your files in project.
    2. Create single or multiple timelines( Depending upon your requirement)
    3. Import menu ( from library or your own), if you want menu should be a part of DVD.
    4. Set first play to any timeline or menu.
    5. Do linking to menu ( if you want)
    6. Preview from File menu and check all things work as expected.
    7. Go to Build Panel.
    8. Select Format as DVD and Output as DVD Disc .
    9. Check Recorder (Burner) availability, some Burner should be connected and visible.
    10. Insert Disc in Burner .
    11 Click on Build Panel.
    12. Building will start, after build is successful , check disc on DVD player.
    I hope these steps will help you.
    Minu
