Activity › Forums › Adobe After Effects › Simple Drawing effect
  • Simple Drawing effect
    Posted by Tintran on June 29, 2005 at 3:10 pm
    Hi
    I am an AE novice and am trying to create the effect of a simple doodle of a city landscape to draw itself. I have tried using vector paint but the fact is drawing strokes by hand have just given me an inconsistent look and unsmooth strokes. So how can I create this effect but with smooth consistant strokes?
    Tintran replied 21 years, 3 months ago 3 Members · 4 Replies
  • Steve Roberts
    June 29, 2005 at 3:24 pm
    Use the pen tool to draw the doodle on a new solid. Add the doodle points in the order in which you would like them to draw onscreen.
    Next apply effect>render>stroke, set to “all masks”.
    Use keyframes to animate the end point of the stroke from 0 to 100. This will make the stroke appear to draw itself on.
    For other methods, search the COW using the search term “signature”. Search the archives as well.
    Steve
  • Joshua Stanley
    June 29, 2005 at 3:29 pm
    Dude-
    use the pen tool to draw the lines exactly where you want tthe reveal to happen, and then apply effect/render/stroke. In the effects panel change paint style to “reveal original image” and then keyframe the start poition.
    you might need to adjust the stroke width, and you can try it with stoke sequentially turned on and off to see the difference.
    good luck.
    Josh
  • Joshua Stanley
    June 29, 2005 at 3:30 pm
    shoot, steve beat me to it.
  • Tintran
    June 30, 2005 at 1:57 am
    Thanks guys that was a lot of help.
    Tin
