Activity › Forums › Apple Final Cut Pro › Simple cut, video only.
Steve Connor
December 15, 2012 at 6:50 pmSlightly different version of Jeremys, double click the waveform on the clip to expand, press P, hold down B to cut and then you can trim the video only
https://www.youtube.com/watch?v=SihqJA-hnqs
Steve Connor
‘It’s just my opinion, with an occasional fact thrown in for good measure”Some contents or functionalities here are not available due to your cookie preferences!This happens because the functionality/content marked as “Google Youtube” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
Michael Sanders
December 15, 2012 at 9:22 pm1) Select the clip
2) Shift “F” to match frame
3) Shift “3” to switch to audio only mode.
4) “D” overwrite clip to timeline.
Michael Sanders
London Based DP/Editor -
Jeremy Garchow
December 15, 2012 at 9:41 pmThat’s exactly what I was trying to explain Steve.
Thank you!
Emiliano Tidona
December 16, 2012 at 8:22 amMy 2 cents:
-detach audio
-cut the portion of the video you want
-disable it pressing V
