Activity Forums Apple Final Cut Pro Legacy Simple Compressor Question
  • Simple Compressor Question
    Posted by Matt Jones on February 13, 2010 at 12:19 am
    I exported a my 2-hour clip from FCP6 into Compressor. I used the “DVD 120 Minutes Fastest Encode” preset. This will give me an audio and Mpeg-2 video file, which I will then import into DVD Studio Pro to burn.
    Do I have to sync them up in Studio Pros timeline or when I import the asset, will it grab both? Is this all correct?
    My apologies if this is dumb question.
    John Fishback replied 16 years, 6 months ago 2 Members · 2 Replies
  • Matt Jones
    February 13, 2010 at 12:35 am
    Ok check that. I got some Cow advice. I exported a QT reference file to my Desktop. Put it into Compressor, and now I’m encoding with DVD Best Quality 120 Minutes. I assume I simply import my asset (both audio and video files) into Studio Pro and burn.
    The length is 1 second under 2 hours. The QT Ref is 1.6 GB. (No menu in Studio Pro)
    Should I be good here?
  • John Fishback
    February 13, 2010 at 3:17 am
    You workflow is fine. It’s best to use an ac3 (Dolby) audio file instead of an aiff as it’s 1mbps less overhead (and a smaller file) for the DVD player. But, don’t use the ac3 preset without changing two parameters in the Inspector > Encoder > Audio tab: dialog normalization from -27 to -31 and data rate to 192 (it may already be 192, but check); and in the Preprocessing tab make sure Compression Preset is set to None. I’m pretty sure there’s a good tutorial about this on Ken Stone’s site. It’s also covered in Compressor’s user manual.
    John
    MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.8 QT7.6.4 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
    FCS 3 (FCP 7.0.1, Motion 4.0.1, Comp 3.5.1, DVDSP 4.2.2, Color 1.5.1)
